Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 12-13-2004, 03:18 AM
metsup metsup is offline
Question radiator fan has stopped 4 days and then works again?
I have 97 sebring(sweet car) where engine light comes on and upon checkin problem i find fan has stopped working,after days of running her this way i also find no service engine light and fan working again,
Is this a sticky relay switch or what causes this happen,because id rather see the problem fixed than this on and off fan action,
i do hear under the hood a hard sound like something is tryin 2 engage but cant!
anyone got suggestions ? id be most greatful!
Old 12-18-2004, 09:15 AM
bearcatdon bearcatdon is offline
Re: radiator fan has stopped 4 days and then works again?
Are you sure the two are related? Go to Autozone and have them pull the codes. If your fan is not running like it should it may be a faulty/bad connection on the temp sensor or a bad ground. Pull your fan out clean it and try to energize it. If your fan always works when the a/c is on I would lean towards the sensor.
