Old 12-12-2004, 11:31 PM
Savior1974's Avatar
Savior1974 Savior1974 is offline
I GOT MY CAR BACK. Big difference but also I got a big problem.
OK guys, I got my car back after I put all the mods on it, and I gotta say, it's too damn fast now!!!!!!!!!!! Scared the shit out of me when the boost kicked in. But I got a problem, When I rev up the car, It revs fine. But when I suddenly let go of the gas and the revs fall, they fall below Idle point and sometimes causes the car to shut off. Also, when I'm driving the monster, and lets say the revs are at 5500, I push in the cluctch and put it in neutral, the revs fall below Idle and the car shuts off again. Please tell me whats going on. And yes, my blow off recurclates into the intake. Also I found out that if I slow the car down to about 1500 rmps before I push in the clutch, it doesn't shut off. WTF!!!!!!! BTW here the mod list in case you need it.
Act 2600 clutch
Apexi N1 3" downpipe
3" exhaust and Hks 3"-5" muffler
Greddy Type s blow off valve
Autometer Boost/Vac gauge and Air fuel Gauge
AGP Garrett T3/T4 60-1 turbo
Tial 38mm Wastegate
AGP Spearco FMIC
Greddy Profec B Spec 2 Black
HKS Turbo Timer Type 1 Black
Dejon 3.5 Intake / K&N Air Filter
DSM LINK
95 GSX Eprom ECU
950cc Fuel Injectors
Walbro 255 HP Fuel Pump
Aeromotive Fuel Regulator w/ fuel lines
SBR TPM Drilled/Slotted Rotors
Brake Pads
B&M Short Shifter
Also, I'm only running 15psi.
1998 Eclipse GSX (Sold)
Act 2600, Apexi 3" downpipe, 3" exhaust, Hks 3"-5" muffler, Greddy TypeS BOV, Autometer Boost/Vac & Air fuel Gauge, Garrett T3/T4 60-1 turbo (Only boosting 15 psi) Tial 38mm Wastegate, Spearco FMIC, Greedy Profec B2, HKS Turbo Timer Type, Dejon Intake/K&N Air Filter, DSMLink, Eprom ECU, 950cc Fuel Injectors, Walbro 255 HP Fuel Pump, Aeromotive FPR, Drilled/Slotted Rotors, B&M Short Shifter
Old 12-12-2004, 11:35 PM
Savior1974's Avatar
Re: I GOT MY CAR BACK. Big difference but also I got a big problem.
another thing I noticed is that when I'm in neutral, the air fuel gauge I have falls so low into lean, that the light doesn't even turn on....... is that the problem?
Old 12-12-2004, 11:48 PM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
do you have an AFC you may need it or dsm link to be tuned a little more
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 12-13-2004, 12:02 AM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
Fuel cut?
Old 12-13-2004, 12:29 AM
Savior1974's Avatar
Got dsm link, probably does need to be tuned more but I don't know what to tune to stop what it's doing.. Also It's not fuel cut. Got a good fuel system.
Old 12-13-2004, 06:27 AM
DreDay1984 DreDay1984 is offline
Banned
does it shut off like right after you let off the gas? cause mine does that to i dont think its the fuel cut
Old 12-13-2004, 06:51 AM
Banned
hmmm now that ive notice your injectors are freaking huge i have eveything you have on your car plus a turbo upgrade and a front mount and i only have 660 injectors so maybe ask about those i dont know my car when im sitting in my drive way and i rev it up to like 4-5 its stalls out
Old 12-13-2004, 07:18 AM
Vtec95Civic Vtec95Civic is offline
Yeah your injectors seem very large for your setup.
Old 12-13-2004, 07:28 AM
Banned
650 i meant
Old 12-13-2004, 08:08 AM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
His injectors are fine, he has DSMLink and a FPR. Make sure you dont have a vacumm hose loose or anything. Mine did the same thing and it was a vacuum hose near the driver side firewall.
Dre. Day He does have a Turbo and a FMIC, He has a lot of mods on that car, Did you read the list fully.
[color=blue]Act 2600 clutch
[color=blue]
Tial 38mm Wastegate
[color=blue]
DSM LINK
95 GSX Eprom ECU
Brake Pads
B&M Short Shifter
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 12-13-2004, 09:27 AM
Banned
is that what the profec b is?
Old 12-13-2004, 09:36 AM
96ws6 96ws6 is offline
Do the eclipses have an iac valve. Try this, rev the car in neutral, slowly let it come back down to like 2500, then let off the gas completely. My firebird did about the same thing when I removed the iac valve from the tb. I had to adjust the tb blade stop to keep the idle just a tad high, but keep the blade open just a tick, it kept it from slowing down below idle and dying. As far as the lean idle, you may be pulling the fuel through the exhaust valve before it has a chance to fire, then the sudden rush of air behind it will trick the sensor into thinking the car is lean. A lean idle wont really hurt anything, just as long as you dont lean it out on top.
Old 12-13-2004, 10:01 AM
evo8isgreat evo8isgreat is offline
Hmmm... It may be that you have a bad ICM. I have seen it either do idle surge or will drop way below idle levels and even cut the car off... It especially will happen at quick revs. You can find these online which are reconditioned. Kind of a pain to install cause you have to take the TB out to get to it, plus if you dont get the thing in right your engine will not start.. Good luck!
Old 12-13-2004, 10:15 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If his car worked fine before his mods, I would start guessing boost leak before random stuff went wrong like an isc.
Old 12-13-2004, 10:22 AM
True, but since he has a new intercooler, they sometimes come with upper intercooler pipes. He should still check to make sure it is not damaged or the wires going into it are not cut.
