Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-12-2004, 09:03 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
H22A distributor issue!!
ok i would like to know which is the power wire for the distributor on the OBD-1 H22A and which is the tach wire. or if anybody has a wiring diagram for this or helms manual, it'd be great. Iam trying to figure some stuff out.
thanx.
Old 12-12-2004, 10:50 PM
boytiti's Avatar
boytiti boytiti is offline
Re: H22A distributor issue!!
thanx.
your best bet is to go check out a book for prelude at the library.
your tach wire is always the negative side of your primary ignition coil.
Old 12-13-2004, 02:22 AM
ludeguy ludeguy is offline
thanx.
I might try and help you out with this tomorrow, unless you have it figured by then - in the meantime if you need wiring help, check the manual at www.hondahookup.com/manuals - i don't know if your h22 is in a 4th gen - but the manual for that should help ya all the same. it's a 38 meg pdf, download at your own discretion.
Old 12-13-2004, 10:57 AM
boytiti's Avatar
Cool Re: Re: H22A distributor issue!!
92-95 prelude is OBD I. 96 and up prelude is OBD II. i think the dude is just trying to find which one is the tach wire. tach wire is usually colored blue. ignition coil primary has positive and negative connectors.
the positive connector is for battery (positive terminal) and the negative side of the coil is for signal wire. this is where the tach wire (blue) is connected.
see my ride at >> http://preludevtec93.tripod.com/pics
Old 12-13-2004, 11:13 AM
Re: Re: Re: H22A distributor issue!!
yah i agree - I was just trying to point him in the direction of a manual, for his obd1 question - so he could get a diagram like this one. looks like you were right the blue wire is the tach one.
Old 12-13-2004, 03:01 PM
boytiti's Avatar
Re: Re: Re: Re: H22A distributor issue!!
so is that the wiring diagram for OBD I h22a distributor?
Old 12-13-2004, 03:23 PM
Thumbs up
it's from a 93 prelude helms - should be (:
Old 12-13-2004, 07:40 PM
i'm actually trying to figure out the power wire(+) from the harness that connects to the dizzy because its faded and cant tell the colors apart.
Old 12-13-2004, 08:37 PM
isn't it the yel/grn wire - that goes from the ecu - to the ICM (the ICM is inside the dizzy)
the pins on your ecu for that wire are
A21 yel/grn1 ICM
A22 yel/grn2 Shorted to A21
i don't know that i'm fully following you.. but i hope that helps.
Old 12-13-2004, 09:35 PM
thanks! got it! i'll have to wait till tomorrow to test it out because i'm still running a straight pipe until my HFC comes in, too many cops out tonight for some reason!
thanks again.
