Old 12-12-2004, 08:01 PM
islandguy1969 islandguy1969 is offline
Thumbs down bottom piece of upper intake manifold
99 windstar 3.8........Did TSB on intake manifold today, went fine, BUT! bolt hole # 10 (bolt tightening sequence) is stripped.
my questions: is there a way to get that brass piece pressed out and a new one pressed in?
having it tapped out: its a #10 metric bolt, what size tap do i need to obtain?
OOOOORRR.......will i be buying a new upper intake?
HELP!!!
Old 12-13-2004, 04:25 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: bottom piece of upper intake manifold
I have a '97 3.8l so the intakes are a little different... where is the threaded part, in the lower intake manifold? If so, then you may be able to install a Helicoil replacement thread insert, but you would want to pull the manifold and do it in the shop, not on the engine.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Old 12-13-2004, 06:58 PM
Re: Re: bottom piece of upper intake manifold
Thanks dngrsone, i believe u have pointed me in the right direction
