Go Back   Automotive Forums Car Chat > Buick > Regal
Old 12-12-2004, 07:32 PM
ind3ciso ind3ciso is offline
1992 Regal- Cd player install.
I looked around and coudnt find anything on this.
i have everyething i need mounting kit, harness antenna adapter.
Do i just take off the trim on the dash and access that cluster of wires, i have heard they are behind the glove box
Please help. Thanks
Old 12-12-2004, 09:26 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 1992 Regal- Cd player install.
http://carstereohelp.com/stereoremovalBuickRegal1.htm
Old 12-13-2004, 12:43 PM
thanks but i knew how to get off the trim peice.
my main problem is i cant find the plugs that plug into the wiring conversion harness that came with the cd player install kit.
and where is the antenna plug?
Old 12-15-2004, 02:18 AM
AZeline's Avatar
AZeline AZeline is offline
Start pulling the radio out then unplug it when you have room to slip your hand in. There should be just barley enough slack.
The antenna plug on my 96 is not the standard motorola plug. You may need an adaptor if yours is smaller than the normal plug. As far as the plugs go, Ask an instal tech for a proper adaptor. You should just be able to attach a harness adaprtor to the wires of your new CD player then plug that into the factory harness. It probably fell into the dash somwhere if your still looking for it. I'm assuming you already have the original radio out..
Old 01-14-2005, 02:19 PM
Puddy905 Puddy905 is offline
Re: Re: 1992 Regal- Cd player install.
Just in the process of the install on my buddies 93. The control unit/harness is behind the glove box. Juts take the kick panel on the pass side out and the liner from the glove box and it's accessible from there. I am having one problem though. The harness fits great and everythings good, but I can't power on the deck. I will be troubleshooting tonight with the old voltmeter.
Old 01-14-2005, 02:21 PM
PS. the antenna plug is also there. Basically, the stuff you took apart in the dash is useless...it just acts like a remote to the actual control unit.
