Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-12-2004, 07:23 PM
freebird225 freebird225 is offline
Angry Wont Start, Instrument panel Going nuts
Last night 2000 JGC Laredo ran fine to store. Came out and tried to start and all guages spinning back and forth, turn key... Nothing. Had it towed home. Turn headlights on relays above fusebox under dash go buzurk ticking. Swapped around relays, no change. No blown fuses, battery reads 11.3 V. After many hours I got panel to look normal a couple of times for odometer to say DONE, no codes. Headlights turn on 1 out of 10 tries. Cleaned and tightened all visible ground wires. Any ideas???
Old 12-12-2004, 09:41 PM
xj31 xj31 is offline
Re: Wont Start, Instrument panel Going nuts
did you try jumping it?11 volts is kind of low.you might need a battery
Old 12-13-2004, 07:28 AM
collegejeep collegejeep is offline
My 2000 was doing the same thing a few months ago, replaced the battery with, and put in one with more power this time, andn everything is working fine.
Old 12-13-2004, 08:39 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
instruments going crazy is a sign of a bad battery. change the battery possibly get jumped like xj said.
Old 12-13-2004, 08:41 PM
leowolf leowolf is offline
Clean the battery and terminals, use a wire brush inside the terminals and on the battery posts. charge the battrey. check the volts once it is started, if the volts are between 13 and 15 vdc turn the car off the charging system is good. turn the lights on for 5 minutes with the engine off. test the battery volts with the lights off. if the volts have fallen below 11, replace the battery. also if the volts drop below 9 while starting... change the battery.
Old 12-15-2004, 01:08 PM
buffalo buffalo is offline
Battery needs replacing, that's all.
Forget all the tests, waste of time!
Good luck.
Old 12-16-2004, 10:20 AM
Re: Re: Wont Start, Instrument panel Going nuts
that's right you've got good hard earned cash to throw in the toilet for a couple of 2 dollar terminals, just replace the battery, i'm just a newb idiot with 25 years of experience in automotive and electonics.
good luck!
Old 12-16-2004, 12:31 PM
Thumbs up Re: Re: Wont Start, Instrument panel Going nuts
Originally Posted by leowolf
Clean the battery and terminals, use a wire brush inside the terminals and on the battery posts. charge the battrey. check the volts once it is started, if the volts are between 13 and 15 vdc turn the car off the charging system is good. turn the lights on for 5 minutes with the engine off. test the battery volts with the lights off. if the volts have fallen below 11, . also if the volts drop below 9 while starting....
replace the battery
change the battery
