Old 12-12-2004, 06:23 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Talking Looking for a 6-bolt
does anyone know where i can find a 6-bolt motor or less than 2 grand. Will i have to get a new transmission for this to fit in my car or is it a direct swap?
Old 12-12-2004, 06:38 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Looking for a 6-bolt
No you will not have to get a new tranny, you will have to do some modifications to the drivers side motor mount. Other than that, rewire the CAS and everything will work fine.
You can find 6 bolts all over the internet... I have 4 complete motors on engine stands in my shop right now, 2 of them are in the process of being used. They are not hard to come by.
www.dsmtuners.com/classifieds
www.dsmtrader.com
www.ebay.com
Old 12-12-2004, 11:41 PM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
if you want to do it yourself I have a 1991 tsi block with crank and rods and others for sale for $200 plus shipping. the block was tanked and surfaced, the cylinders are ball honed and surfaced, the crank is balanced and pollished, the 1g oilpump is there, along with many other parts, like timing and crank pullies. the shortblock is 90% complete and disasembled leaving you only needing a head and bearings and gaskets, I can throw on new arp main studs and rod bolts for another $100. arp fasteners are brand new and still in packaging. THIS IS A 6-BOLT BLOCK.
1g oil pump gasket kit $28
1g main seal $15
2g head $125 each I have two
2g intake manifolds $125 each including sensors
and many more parts many trades may be concidered
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 12-13-2004, 01:10 AM
EclipseRST's Avatar
Banned
If I were doing a 6 bolt swap i would never put a 2g head on it! Whats the point in going through all the trouble and not having any gain from it?
Tyko, shrink down your sig... Its way too big, put the cars side by side or take one out.
Old 12-13-2004, 01:58 AM
Re: Re: Looking for a 6-bolt
I really wouldnt do it either thas why I have two for sale...
Old 12-13-2004, 02:03 AM
i have found quite a few but they mostly are runnig 1100-2400
Old 12-13-2004, 02:26 AM
i just found a jdm motor with 30,000 to 45,000 miles with the awd transmisison and the jdm ecu for 1699. But i have to pay the import tax of 2.5% im sure that will suck then to have it installed im my car that will suck also. I would have to have it done in 2 days cause it is the only car i have.
Old 12-13-2004, 02:38 AM
EclipseRST's Avatar
Banned
Do you have any access to a cherry picker (engine lift) and some tools? Maybe a jack and some jack stands also?
Old 12-13-2004, 02:43 AM
EclipseRST's Avatar
Banned
Actually I just happen to know of 3 in the Texas area that are all under $1000. Now if you are looking to spend around $2000, you could buy a motor for under $1000, and spend the other $1000 getting someone to put it in!
Old 12-13-2004, 05:01 PM
x~Underoath~x's Avatar
x~Underoath~x x~Underoath~x is offline
Send a message via AIM to x~Underoath~x
Okay...well I just found a jdm cyclone 4g63 while I was looking around and stumbled upon a question. What if the engine comes with no wiring harness and all that jazz? My question is this...Can you use all of your pre-existing wiring and other electronics(ecu?) from your old motor?
1990 Nissan 240sx SE(5spd)(Megan R. Coilovers)(5Zigen FN01rc 17x8 +35: For Sale)
Wanted: Some sort of 15-16x7-8" mesh wheels, black w/polished lip. And a nice offset.
DRFT 1337 [8:10 P.M.]: i figured out how to make my dick 12 inches
OurOnePassion [8:10 P.M.]: WOW
DRFT 1337 [8:10 P.M.]: fold it in half
DRFT 1337 [8:10 P.M.]: that is how i make it 12
Old 12-13-2004, 06:15 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Check out www.jdmsource.ca It is company out of Calgary, Alberta, Canada. I just got my JDM 4G63T Turbo for 1600CDN (1300USD). Came with new tranny as well. Only 30 000 kms ish on it, perfect compression and guaranteed less than 5% cylinder leakage (i think)
As well, I have a stock 4G63T Engine for sale. Good compression, low cylinder leakage, all that fun stuff. It is out of 94, not sure if it is 6/7 bolt, I always get confused, someone let me know please.
interested? [email protected]
Later!
"You can have everything in life you want if you will just help enough other people get what they want."
Old 12-13-2004, 07:41 PM
95 cyclone 95 cyclone is offline
im swapping my 95 fwd w/ a 6 bolt right now. i picked mine up for 500 with the whole car. the motor needed work but after 2weeks of tearing the block apart, everythings going together pretty solid.
ill let u know when i come across one again.
Old 12-13-2004, 11:57 PM
Quote(Actually I just happen to know of 3 in the Texas area that are all under $1000. Now if you are looking to spend around $2000, you could buy a motor for under $1000, and spend the other $1000 getting someone to put it in!)
where are they had? do they come with the transmission and ecu also? How many miles on them. you know all of the questions im going to ask you so if you could give me a pretty good understanding on the three motors. Im in the process of trying to get one here pretty soon may be a little after christmas
