Old 12-12-2004, 05:31 PM
Midnight Racer's Avatar
what happened
I need help bad.I sprayed my Supra on Friday and the first thin coat came out flat and so did the second so I stopped and would like to know what happened to the paint.I used krylon spray.
Old 12-12-2004, 05:42 PM
Fastphil's Avatar
Fastphil Fastphil is offline
I'm not a pro, but it looks to me like you didn't wash the body before you started painting it.
Old 12-12-2004, 05:43 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: what happened
I had the same exact problem with my camaro when using Krylon Fusion White. No matter how much I sand it down, the ripples don't go away. Anyone know how to solve this?
Old 12-12-2004, 05:44 PM
Re: what happened
I did wash the body.
Old 12-12-2004, 05:46 PM
Fastphil's Avatar
Re: Re: what happened
What kind of paint are you using then?
Old 12-12-2004, 05:49 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
looks like you didnt use primer?,and it looks to have etched the plastic
Old 12-12-2004, 06:03 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
Re: what happened
He probly used that crylon plastic bonding or whatever spray paint.....not good for models.
Project Lexus Revive
lilbudman's Avatar
lilbudman lilbudman is offline
Send a message via AIM to lilbudman
Re: what happened
Theres you problem right there. I've never had any luck with Krylon, I once got a can of nothing but over spray, Id strip the body down with brake fluid, and see what you've got, I always use Duplicolor Auto Spray.It's really good paint and it pretty cheap.
Lilb'budman
Thanks to me for learning how to make my own God damn sigs!!! J/k If anyone needs a sig PM me.
Old 12-12-2004, 06:06 PM
RallyRaider's Avatar
Zomby Woof
Re: what happened
I agree with James. Primer is essential if you are using "hot" automotive paint. Otherwise the solvents will eat into the plastic. Good for a strong bond but not good when the plastic is damaged. You could possibly sand the bad areas down, prime and try again.
Old 12-13-2004, 01:07 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Re: what happened
I have the very same problem last week on a Aoshima Nissan Silvia S15. Washed, Tamiya Fine Primer and then a few dust coats of Tamiya TS14 Black then a few wet coat and it came out like this. No matter what I did it was still the same. It's in Dot 4 now being stripped.
I put mine down to the cold weather and humidity, but not really sure why
Steve a.k.a. Hiroboy
Old 12-13-2004, 01:12 AM
BRM BRM is offline
Re: what happened
I'm having similar problems with Tamiya X-18 drying flat. Any ideas about that one? It really screwed me up when doing some touch ups.
In progress: 1/24 Protar Mercedes W196, Mercedes AMG CLK GTR SS conversion.
Old 12-13-2004, 01:26 AM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
I had Krylon do that to me on the Cobra in my avatar, I just sprayed another coat after a few minutes and it laid down smooth.
