Old 12-12-2004, 03:57 PM
intimidtr3 intimidtr3 is offline
95 2.2 help needed
I have a 2.2 5 spd that is in need of help.I just put plugs,wires,pcv and air filter in it.It ran better for a minute then not.It has no power starting off or driving.Won't even do highway speeds.It idles fine but even no load accelerates slow.Even slower moving the truck.Is this a normal fix or where should I start looking.
Old 12-12-2004, 05:09 PM
Fractured1 Fractured1 is offline
I would lean towards a restricted converter...also check to make sure none of your exaust pipe is bent shut...
Old 12-12-2004, 06:50 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 95 2.2 help needed
did you replace the fuel filter.
even if it isn't the cause a clean fuel filter will save your fuel pump in the future
Old 12-12-2004, 08:38 PM
Does not have a converter.Was off before I got it.Was thinking about the filter though.
Old 12-14-2004, 09:24 PM
xtremetrk xtremetrk is offline
It could eith be that since you have no converter the o2 sensor is reading incorrectly or that you replaced the spark plug wires in the wrong order.
Old 12-18-2004, 11:10 AM
s10er s10er is offline
Have your head checked. I had similar symptoms and thought the converter was bad. Turned out the be a cracked head.
