Old 12-12-2004, 03:23 PM
GPme GPme is offline
Fuel System Problem?
Have a 97 Grnd Prix GTP new since 97. Had a lot of stuff changed out since then. CURRENTLY, I have a NO START situation. Doesn't seem to be getting gas to plugs.
I changed the Fuel Pump related RELAYS and checked the FP related fuse. Car worked for a day after relays were changed, BUT NOW IS NO START. I checked the fuel pressure and there is NONE. Does this should like fuel pump problem. IF SO, is it in the gas tank and is the change out job a tough one? I looked up the price of fuel pump and got quite a shock at approx $300! WOW! Id like to try to do job myself if not to difficult.
Thanks for the help.
GPme
Old 12-12-2004, 04:02 PM
BIG-L's Avatar
BIG-L BIG-L is offline
I take it,you have replaced the fuel pump resistor that is located on the inside of the passenger side fender????That is a problem with our cars and alot of folks dont know about it,since it is tucked away inside the fender.
This should help with the removal of the fuel pump.
Disconnect the vehicle’s battery. Remove your spare tire, jack, and pull back or remove the carpeting in your trunk. You will see a plate at the front of the trunk right behind the rear seat.
Remove the seven 10mm nuts on the plate and gently use a flat-blade screwdriver to pry the plate up.
Remove the two electrical weatherpack connectors and the three fuel line connections. Remove the two outside fuel lines by squeezing the clear plastic retaining clips together and pulling outward. The middle fuel line is removed by applying a gentile squeeze to the black ring and pulling outward. Remove the retaining c-clip around the pump assembly.
Remove the in-tank assembly by pulling up and sliding the whole assembly up and out of the tank. Be careful as you remove the assembly because you will have to maneuver the end of the assembly to the side to remove it due to the tank level sender and fuel sock. DO NOT FORCE THE ASSEMBLY OUT. Rotate it and tilt it to the side until the assembly slides out.
Hope that helps
~Larry~
ClubGP Member 6530
Since 2001
Old 12-12-2004, 04:22 PM
Re: Fuel System Problem?
Dear BIG L,
Thanks for the GREAT info on replacement of the fuel pump. I'm sure I can pull it now, if necessary, HOWEVER, you mentioned the "fuel pump resistor". I don't beleive a replaced this. I replaced the RELAYS within the fuse box under the hood on the passangers side.
Do you know where the FP RESISTOR is located. Is it on the pass side fire wall? Pass side FENDER inside the engine compartment. Or is in actually UNDER THE FENDER and accessable by taking the passanger wheel and wheel shroud off?
You have been very helpfull. Appreciate your insite and assistance.
GPme
GPme
Old 12-12-2004, 04:49 PM
BIG-L's Avatar
Here are some instructions for replacing the fuel pump resistor Click Here and you can either get the kit from your local dealer GM PART # 88951182 which lists for 44 bucks or you can get it from www.gmpartsdirect.com for 32 bucks to your door.
Id try the resistor first.
~Larry~
ClubGP Member 6530
Since 2001
Old 12-12-2004, 07:39 PM
troy1 troy1 is offline
AF -Advisor
Hey does anyone know do 95's have this cover also?
Old 12-14-2004, 11:58 AM
BIG-L's Avatar
Here is a quick way to test the fuel pump resistor
~Larry~
ClubGP Member 6530
Since 2001
Old 12-14-2004, 01:59 PM
dwalmop dwalmop is offline
Do all GM W bodies have the fuel pump access hole?
Old 12-14-2004, 03:03 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Yes
Old 12-15-2004, 02:33 PM
IT'S FIXED AND RUNNIN, for now...
My thanks to BIG L and all who responded to my thread. The info I was given from you all helped to correctly diagnos my problem so that I was not ripped off.
My fuel pump and filter were replaced. Didn't need to do the fuel resistor thing, so I'm taking that part back to the GM dealer where it was purchased, they had it in stock.
Fuel pump was $300 for part with $75.00 to install. Fuel filter was $10.00 part and was included with fuel pump install.
I have $180,000 miles on my 97 GTP and need to get as many more as I can. I am saving up to replace the super charger, of which I know will need to be replaced soon.
Thanks again, I'm sure I will be "threading" you all again.
GPme
Old 12-15-2004, 04:04 PM
BIG-L's Avatar
Most of the time on the supercharger,the coupler goes in the snout and it starts making a rattling sound at idle or as others say a rock crushing sound.You can get one from the below link for about 36 bucks and a snout rebuild kit for 89 bucks including 2 bottles of GM SC oil.The only thing you would need is to take it to a machine shop to have them use a Hydraulic press for the install of the bearings.So dont let the dealer sell you one for $2,500.00 when for a total of 150 bucks you can have it done yourself.Here are some instructions for taking off the snout Click Here
www.zzperformance.com
ClubGP Member 6530
Since 2001
