Old 12-12-2004, 03:06 PM
huliogman88 huliogman88 is offline
Send a message via AIM to huliogman88
Trans Am Issue
So i went to go test drive a 1995 trans am this morning because i am considering buying it and i came out with 2 problems. or potential problems. The car has nitto drag radials on it and i realized when accelerating fast it swayed side to side (not like traction loss but the body swaying but tires remaining in a parallel line w/ the road). the guy told me that this has been happening even since he got the radials on it but im wondering if it could be the suspension or something...
does anyone know what the problem could be with it. im planning on getting it checked out before i buy it but am wondering if this is a major problem or a common problem with that kind of tires that isnt even worth getting it checked out for.
the other problem is less severe but i cant think of what to do, the low coolant light was on when i went to drive it, he told me that he was messing with something and lost a bit of coolant but it isnt leaking or anything. is this a major concern?
Old 12-12-2004, 03:13 PM
82KnightRider's Avatar
82KnightRider 82KnightRider is offline
Maybe a sway bar
Old 12-12-2004, 03:27 PM
what about it. think i need to buy a rear sway bar? i mean, it doesnt bother me, but i just dont wanna buy the car if it is a HUGE suspension problem or sumthin. would i have to buy a sway bar?
thanks for posting
Old 12-12-2004, 03:47 PM
I have a third gen with suspension issues ,it goes side to side in the rear,bounces on uneven roads,and goes back when I gun it but then it evens out after a second.I am going to install new shocks,struts ,springs,pan-hard bar ,pair of trailing arms in the rear and I hope it fixes my suspension issues.I have a third gen and dont know how much different they are from 4th gens,as far as suspension goes.
Old 12-12-2004, 03:57 PM
Re: Trans Am Issue
so basically, ill be fine tho for a while. as long as my cars wheels arent gonna break off lol
Old 12-12-2004, 04:52 PM
hey man ,dont test ure luck when ure flyin down the hughway.Id get them checked
Old 12-12-2004, 05:27 PM
Re: Trans Am Issue
k, i think i figured it out, sum1 told me this, because drag radials have a soft sidewall so the reason im swaying is because the tires r twisting and being distorted when in fast acceleration. can someone confirm this for me.
thanks for the posts in advanced
Old 12-12-2004, 05:59 PM
CreepingDeath94 CreepingDeath94 is offline
If they are true drag tires witht he soft sidewalls then yes, it will cause a sway feel.
Old 12-16-2004, 10:19 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Re: Trans Am Issue
hit a few hard corners,and listen to see if the tires rub the inside of the rear well.if not dont worry too much.
Old 12-17-2004, 02:00 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Re: Trans Am Issue
that is true, soft large sidewalls can cause swaying
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 12-17-2004, 02:24 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
check the bushings in the rear end. Drag raidals don't have that soft of a sidewall to cause that, slicks do but not DR's.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 12-17-2004, 01:27 PM
1988TransAm's Avatar
1988TransAm 1988TransAm is offline
Re: Trans Am Issue
I agree with Hppsi87, if the bushings are bad, or even been removed you will get some radical feelings like the rear end is swinging out, as if you were trying to smoke the tires off the line. Not a safe condition.
Old 12-17-2004, 03:05 PM
Re: Trans Am Issue
makes ya wonder if its drivin down the street a lttle / /
