Old 12-12-2004, 02:50 PM
sLADe781 sLADe781 is offline
P0442 - Evap
I took my sister's '97 Eclipse GS to AutoZone today and pulled the code with the OBD II scanner thing since the Check Engine light has been on for quite some time now. The scanner gave me the number P0442 and said "EVAP - Emissions Control System Leak (small)." Does anyone know that means? I asked the guy behind the counter and he said that I have a vacuum hole somewhere in one of my tubes and just had to replace it. Is that right? If so, how do I locate the hole? Thanks.
Old 12-12-2004, 11:02 PM
Re: P0442 - Evap
Old 12-12-2004, 11:31 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: P0442 - Evap
check for a vacuum leak on all your vacuum hoses. if you find a hose disconnected, find where it goes and put it back on and if you find a hose w/a hole in it or cracked or something, replace it.
95 Talon TSI AWD
97 Eclipse GST
Old 12-16-2004, 02:11 AM
royboy15931 royboy15931 is offline
Re: P0442 - Evap
Check out my posts elsewhere by searching "p0442 eclipse" to get some ideas.
Old 12-18-2004, 03:57 AM
Re: Re: P0442 - Evap
I did do the search but have already looked through the ones that matched. I'm still stuck....
Old 12-18-2004, 08:47 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: P0442 - Evap
Check the hose on top of the tb (the plastic one). Better yet just replace it with new a hose, shouldn't cost you more than $1
For Sale 98 Eclipse GS, 5 spd
Old 12-18-2004, 01:55 PM
I'm not too sure which hose you're talking about. Do you have a picture?
Old 12-19-2004, 08:49 AM
ashah000's Avatar
Re: Re: Re: P0442 - Evap
You can't miss it. Look on the top of the throttle body. There is a hose there that runs from the TB the the back of the firewall somewhere (I think it runs to the firewall).
Looking from the top it looks like this:
__________________________
.............................x_______|
Ignore the dots
x= Nipple on the tb
Old 12-19-2004, 08:35 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: P0442 - Evap
make sure your gas cap is on tight. see if autozone has a gas cap tester or try just replacing your gas cap.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-19-2004, 11:02 PM
Cool Re: Re: Re: P0442 - Evap
Your getting good advice so far.
Hey! Do you think your sister would go out with me someday if I fixed her car since my current girlfriend won't see me since I changed her oil without asking permission? Oh well. That's another story.
AS far as which hose to check, there should be NO hoses disconnected,split,or hissing under the hood, behind the right front fender panel, or back at the gas tank. There's a good manual at lindertech.com call "Getting to know OBDII" that should help.
Old 12-20-2004, 01:42 AM
Re: Re: Re: Re: P0442 - Evap
royboy15931, not a chance! LOL Anyways, ashah000 is this the "thing" that you're talking about: http://www.geocities.com/slade781/DSCF1911.jpg
cbell77, if you read this, I hope you don't mind but I pulled the picture off the pictures you posted and circled that one thing since I don't have a picture of my sister's engine. Thanks for the help guys.
Old 12-20-2004, 09:54 PM
Re: P0442 - Evap
I just spent another day trying to figure out what's wrong with her car and still no luck. I'm about to throw in the towel and take it to a shop....how does mechanics know where to look?
And ashah000, I know what you were talking about now. I didn't replace the plastic part you were talking about but replaced the rubber thing that connected the plastic and throttle body because it was cracking...still no luck though.....UGH!!!!
Old 12-22-2004, 12:59 AM
Re: P0442 - Evap
The good mechanics read manuals to understand where to look. The poor ones replace parts at your expense. I've had to read about ten books to understand this complex problem your working on. So don't feel bad.
The part you circled is a PCV valve which is not a part of the problem. So that leaves you with looking in the three areas I mentioned in my previous post or taking it to a mechanic. LOL
