Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 12-12-2004, 01:53 PM
pro1911a1 pro1911a1 is offline
torque spec for 96 Passat VR6 (rear brake)
I am about to replace the rear brake disc/bearing and pads myself. What's the torque spec. for caliper guide pin bolts and rear hub nuts?
Thanks in advance.
Old 12-13-2004, 02:47 PM
boschmann boschmann is offline
Re: torque spec for 96 Passat VR6 (rear brake)
Rear caliper mount bolt is 26 lb/ft & the carrier mount bolt is 48 lb/ft. If you're talking about the nut that holds the bearings it doesn't have a specific torque. While turning the rotor place a flat tip screwdriver between the thrust washer & hub. Tighten the nut until you cannot move the washer then back the nut off until light pressure can move the washer back & forth. Lock in place with the castellated cup & cotter pin.
Old 12-14-2004, 10:45 AM
Smile Re: Re: torque spec for 96 Passat VR6 (rear brake)
Thanks very much. Are these torque specs apply to the front brake also?
Regards.
