Old 12-12-2004, 01:25 PM
Canabalooza Canabalooza is offline
water in back of my rex
so every time it rains everything in the back of my rex gets all wet. i dont think its coming from the hatch because its dry when i check it so maybe something else is leaking? anyone had this problem before or should i replace my seals. i do know that part of the seal for my rear side window is broken on the outside but i tried to pour water in it and it doesent leak atleast not when im watching it.
Old 12-12-2004, 01:59 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: water in back of my rex
It could be the weather stripping on the hatch, cracked seam sealer, taillights, sunroof. Alot of possabilitys.
Old 12-12-2004, 03:09 PM
JiNx_89CRX's Avatar
JiNx_89CRX JiNx_89CRX is offline
Send a message via AIM to JiNx_89CRX
i have that problem too but mine is only in the spare tire spot. The carpet is dry tho. idk where its coming from. I mite just end up drilling a hole.
Cars
89' Honda Crx
03' Mitsu Lancer
Old 12-12-2004, 03:11 PM
Forunn Daberator
that means its probably runing down behind the pannels.
Old 12-12-2004, 03:16 PM
JiNx_89CRX's Avatar
the rear window panels? i may need to run new hoses?
Cars
89' Honda Crx
03' Mitsu Lancer
Old 12-12-2004, 03:41 PM
Forunn Daberator
if yours has a sunroof you should check the drainage tube.
Old 12-12-2004, 06:52 PM
mines only in the spair spot only too. i do have a sun roof where is teh drain hose?
Old 12-12-2004, 08:36 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
that's one of the probs with our cars, the engines etc. last longer than the body parts do most of the time, like the stripping etc.
anyone have a list of things that are ready to go out after 14 years so i can go ahead and replace them before they break? lol
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 12-12-2004, 09:00 PM
Forunn Daberator
Put your car on jack stands, replace everything not touching the ground. Repeat every 15 years.
Old 12-12-2004, 09:22 PM
Sparsky Sparsky is offline
Re: Re: water in back of my rex
That was the issue with mine. Who ever had it before me didn't put the tubes from the roof back into the right spot so it could drain.
Old 12-12-2004, 11:05 PM
Kven's Avatar
Kven Kven is offline
that happend to me, water was coming in threw the top of the tail lights(draining from the "ditch" around the hatch). duct taped it and problem fixed.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 12-12-2004, 11:26 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
my center taillight piece leaks alot and whenever i open the trunk after it rains i get a steady fast drip from it. And when my car was wrecked it filled up a lil in the bottom of the trunk when it was sitting, and it drained when we had it up in the air.
1991 Honda Civic DX Sedan
