2001 4cyl camry oil drain plug torque
anyone know the correct torque required to tighten the drain plug on this vehicle.
Im going to start right now so hopefully there will be an answer when i am finished Thanks |
Do NOT torque it down it will strip the oil pan. Just finger tighten it and then give a 3/8-1/2 turn SLOW AND CAREFULLY with a wrench. Size I believe is 14MM 6 point socket/open end wrench.
Evan Support your local volunteer fire department =============== My Rides: 2003 Ford F-350 Long Horn Hauler Others: 1999 Toyota Camry LE V6-Dad 2004 Chevy Tahoe Z71-Sister 2004 Toyota Camry LE V6-Mom |
seems unusual there is no torque spec. myn honda is 33 ft-lbs but is a bigger bolt
anyone out there know the spec ?? |
If you followed the direction you would be set. If you torque the drain plug you will strip. I guess it is the where bouts of 30ftlbs but i don't think that is needed just hand tightening and finishing it off with the wrench will be sufficent.
I personally think 30lbs is too much it is a much smaller bold therefore i dont believe it would be a good idea.
I understand you are trying to help and i apprecate it but they make torque wrenches for a reason and also have torque specs in the service manual also. im sure it does not say "Just finger tighten it and then give a 3/8-1/2 turn " in the service manual. i have a service manual for my vehicle not this one and i thought if anyone out there has a camry with a manual they could just let me know what the spec is. I guess not I thought i was asking a fairly simple question. Please do not get me wrong I appreciate you trying to help but i just want the facts I have common sense and all but wanted to be correct not guessing at it looking for a # |
Re: 2001 4cyl camry oil drain plug torque
The factory torque is 27 ft-lbs.
It worked fine until I fixed it!
