Old 12-12-2004, 03:57 AM
krazykoncepts krazykoncepts is offline
bet you cant guess what wrong...electrical
I have had the following symptoms on my 2002 windstar almost a year ago, for about a week then it whent away(other then the fact the display would say the rear hatch is open) and now they have returned...
-if you replace the fuse it will either blow immediatly or will work until you stop driving then blow (not sure wut fuse i have to check when i get home, its under the dash by drivers left foot, its a blue fuse)
-brake lights dont work
-wont go into gear cause of it
-interior lights on sliding doors have stayed on before, for no reason
-interior lights wont go on
-key fob will only unlock certain doors depends how it feel on which ones it will unlock
-gauges show no gas
Old 12-12-2004, 07:40 AM
12Ounce 12Ounce is offline
Re: bet you cant guess what wrong...electrical
Here's my "wild guess" of the morning:
Your brake pressure switch ("cruise control deactivation switch"... F58Z-9F924-AA....mounted on the brake master cylinder) is in a failure mode. For a test, disconnect its elect connector...make sure the connector is clean and dry... drive that way for a few days and see if the fuse hangs around awhile.
If the above is not the answer... I have other wild guesses available.
Old 12-12-2004, 04:24 PM
the fuse that continussly blows is fuse 11, its a 15a fuse and controls the electric brake controller, brake shift interlock solenoid, and the rear electrronic module
is there anywere i can find online free shop manuals? or like a haynes manual for the 02 windstar? I am used to working on my rx7 so this windstar is new to me.
also 12 ounce i whent to look at the brake master cylinder is it the small harness that goes into were you load brake fluid?
Old 12-12-2004, 04:26 PM
also noticed another problem when the keys are in accesories spot and a door is open there is a constant beeeeep. It is in the garage so the rear sensor are seeing the garage door but the car isnt in reverse or on. and the beep stops if i close the doors
Old 12-12-2004, 05:26 PM
I found a wire that the insulator was cut a little and the wire had corroded right through, i fixed it but the van had the same problems. So i reset the ecm and drove around the problems seem to be gone. would this make sense or is there still something wrong and this was just coincidence?
Old 12-12-2004, 05:51 PM
krazy
As I said.. it was a "wild guess"... so you can forget the connection on the master cylinder. I was expecting fuse #10 ... not #11. You are on the right track... Rear elect module (not a problem I would guess), and the "brake pedal pos switch" and the "shift lock actuator" ( both good candidates in my book!).
I would start with the brake pedal position switch...inside the cabin at the bottom of the strg col ... senses pedal movement.
Old 12-12-2004, 07:38 PM
i disconnected the brack pos sensor, drove around my street and then parked it, well c if the fuse blows while parked.
Another symptom, when using either the keypad on the door or the key fob u can lock and unlock all doors a couple times then the driver side door gets stuck either locked or unlocked and wont mover unless you put the key in the key hole
