| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
wuts this?
im putin an aftermarket air filter in my car (ya know the cone shped ones) well it fits and evrything, but there was this wire goin into my old filter box, not the wire that goes in the tube its a difrent 1, it goes right in the air filter box. wut is that 4?, is it importent?
-[I belong in tard farm]- |
Re: wuts this?
What is on the other end of the wire? Where is your spell check?
![]() Yes, I am retarded. |
Re: wuts this?
its a air tempiture senseure i found out. do i realy need that?
Re: wuts this?
Yes, but you can just clamp it to the new filter. It should work fine. Good Luck.
Re: wuts this?
camp it on it?, should i try and put it inside it?, is it ok if its not on it on it, like does it have 2 b touching it?, sry 4 all the stupid questions
Re: Re: wuts this?
Make sure you have a good plan for this before you start drilling into your new filter tube. |
Re: wuts this?
is this the thing that reads if my car is overheating?
Re: wuts this?
no, that is the engine temp thermostat. this reads intake tempature. vehicle ECU's are becoming increasingly more complex and advanced. a/f ratios are not being calculated not only by volume of air going into the engine but also density (tempature). it wont hurt much if you dont install it in the intake but the ECU needs to see that signal or you will get a pesky check enigne light and possibly a lean or rich A/F mixture. but not horribly bad A/F mixture. just put it in the intake post air fliter pre flow sensor and you should be fine.
Edit: ive made most corrections, sorry about the spelling, i never could spell and throw my bad typing into the mix and lazyness to not check my self and you have one screwed up post. Last edited by CBFryman; 12-13-2004 at 06:58 PM. |
Re: wuts this?
Wow. You need some serious spell-check help.
But, beside that, what you've read above is what you should do. |
