Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-02-2002, 11:48 PM
bez bez is offline
Lightbulb Custom Cat-back
I have a 96 Civic EX coupe and i want to get a custom cat-back done and i just wanted some advice from you guyes. I dont want to get ripped off so how much do they usually go for? Im also going to get a quiet(yet powerful) muffler, any favorites? Im kind of new at all this so i want to know what the HP increase will be with this setup. Thanks
Old 03-03-2002, 04:03 PM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
a custom cat back shouldn't cost you more than $150 for the piping. Make sure you get Mandrel piping too. I don't know how much that costs though, it may be a little more than regular piping. As for a muffler, if you want one that's not too loud, with considerable gains, go with Thermal R&D.
AF Nordic Crew #3
Old 03-05-2002, 11:31 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
I know that the muffler section back is $60 so i think u could be able to get everything for around $100-$120. I agree with the Thermal R&D as a muffler. it sounds real nice.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-06-2002, 12:09 AM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
Real quick....I am also planning on getting a custom exhaust, but what exactly is 'mandrel bent' piping?
Thanks in advance......
Old 03-06-2002, 04:08 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Mandrel bending
This is when a mandrel is placed inside the piping so as the metal is shaped it does not kink like press bending. It gives a much more even flow for the exhaust gasses to escape then inside a press bend. It will cost around twice as much per bend as the machine costs twice as much.
Dont go bigger than 2inch for your application either as we want performance not noise. Also dont stimp on a quality muffler and get a straight through kind with plenty of packing. Brands are brands spend $200+ and you cant go wrong.:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 03-06-2002, 04:20 AM
Don juan Don juan is offline
How much horse/performance can a custom catback exhaust add?
Old 03-06-2002, 04:26 AM
Depends
On your car I would say with a air filter you would be good for 5+hp. Even more with a programmable chip.:flash:
Why is this in the turbo section?
Old 03-06-2002, 07:01 AM
SleeperTeg's Avatar
What about 2" on a boosted b18b? For some reason I was thinking 2.5" or so with a high flow cat. Thanks...
Old 03-06-2002, 10:16 PM
bez bez is offline
Is there a big differance in HP gains between a custom cat-back and say a greddy? Custom is only 5 HP??????? Also whats a good pipe diameter for a civic? I was thinking 2.25
Old 03-08-2002, 01:50 AM
Depends on fuel
Good sizes for nat aspirated are, up to 1.1lt is 1 and 3/4inch, 1.5 -2.0lt is 2inch, 2.0 - 2.5lt 2 1/4inch, 2.2lt vtecs either 2 1/4 - 2 1/2.
Turbo models add on 3/4 to 1 inch.
Expect 5hp out of a 1.6 to 1.8lt (at the treads) and 5-10hp from a 2.0lt and above from a good system. But power readouts are as good as the dyno they are previded on, a true dyno doesnt loose only 14% through a drivetrain its a shitload more than that.
A Full custom mandrel bent system is the best know doubt, just pick out some quality mufflers and your sweet.
The better fuel though the more power you will make, especially if you dyno tune a custom chip in, remember know two cars are the same.
I run my car on 98ron fuel permenantly and I would use 100+ if we had it.:flash:
Old 03-08-2002, 05:55 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
I will disagree with you on the chip. It will only ad few ponies and only when youre not at full throttle, when youre running a wide open throttle you have same flow w/ stock as w/ aftermarket chip.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 03-08-2002, 06:51 AM
SleeperTeg's Avatar
I totaly agree that a custom mandrel bent exhaust is the way to go...higher flow and cheaper. Why would anybody spend the grip on a bolt on exhaust system??
Uneducated? Afraid to go see Billy Bob at the exhaust shop? I dunno....
Old 03-08-2002, 06:53 AM
SleeperTeg's Avatar
Real quick on hiflow cats...are most shops willing to throw it in for you if you bring it along or do you have to find a clandestine exhaust shop that is willing to tell the EPA to shove it?
Thanks....
Old 03-14-2002, 05:08 PM
Rein Rein is offline
Send a message via AIM to Rein
SO if I were to go into a place that does exhausts, could I simply ask for a mandrel bent exhaust system? Would I just have to provide the muffler? How much would it cost?
1998 Audi A4 1.8T
*APR turbo back exhaust
*APR 1.0 bar chip upgrade (+40 hp, 88ft-lbs)
*Axis Seven 18s
Future mods:
*H&R full coilover suspension
*APR Stage III+ Turbo Kit (310 hp, 345 ft lbs)
*Stop Tech Slotted Big Brake Kit
Click here to check out my car on Cardomain.com
Secondary car: Black 1992 Civic Si
"Every man dies. Not every man really lives"
Old 03-17-2002, 08:05 PM
I am going to kick some ass.
posted by kane2g
That is so much crap If you are running a car that is on standard 92ron fuel and get a chip tuned in for 98ron fuel you will make at least 10-15hp at the wheels.
I have seen three seperate vtec ludes on the dyno then chipped.
1st 94 vtec 99kw at the wheels with 2 1/4 exhaust and intake.
2nd 99 vtec 101.6kw at the wheels with 2 1/2 exhaust and intake.
3rd 2000 vtec 101.2kw at the wheels 2 1/4 exhaust and intake.
All on 98ron fuel than they were all chipped on a 65 degree day.
94 106kw, 99 109kw, 2000 108.7kw all at the wheels, standard at the engine is 147kw or 200hp so you could say they all produce around 158kw or 215hp now that an improvement. WOT what a load of crap.
About the install for the exhaust if you get mandrel bending make sure it is exactly that and yes they will install what ever you want them to. If you want flanges and a cat thay will do that, if you just want the muffler thay will do that, just shop around so you know the average price and then go for it.
:flash:
custom cat back vette_7t9 Elantra | Avante 1 07-20-2005 01:29 PM
custom cat-back Jos4DCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 12-29-2003 07:09 AM
Custom Cat-Back SilverSpec-V Sentra | 200SX (USDM FWD) 1 04-08-2003 12:10 PM
Apex N1 Cat-back and a Bonez SuperFlo Cat - FOR SALE 02MaxSE RX-7 0 04-09-2002 12:21 PM
Custom 2 1/4" cat-back installed!!! Woohoo! NismoPC Engine 0 09-08-2001 07:59 AM
