Old 12-11-2004, 09:42 PM
trey86FB trey86FB is offline
white smoke when starting
my 86 FB with a 305 is smoking when it starts. It smokes when I start it and then stops some one got an anser, and whats the cost to fix.
Old 12-11-2004, 11:00 PM
CreepingDeath94 CreepingDeath94 is offline
Sounds like valve seal...The seals are cheap but the labor to put them in is not...if you do it yourself it will save you a lot of money but take you an afternoon or so of work.
Old 12-11-2004, 11:11 PM
Re: white smoke when starting
Thanks man how do you do it.
Old 12-12-2004, 06:02 PM
well, I would get a manual because there are technical specs that need to be adhered to. It's been a while since I actually performed this job so I would just stick with the manual or wait for someone in this forum to post more detailed directions.
Old 12-15-2004, 04:01 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Up at my job we use a compression gauge hose with the valve stem removed,and a pressure regulator and our compressor to change those seals.of corse we use the valve spring tool to get the two little retainers off each valve,but its a real fast way to do them with the engine still in the car.also a good way to check for leaky valves.I dont put over about 80-90 psi into a cylinder tho,cause im afraid of blowing a head gasket
Old 12-28-2004, 03:28 PM
WickdZ's Avatar
WickdZ WickdZ is offline
White smoke sounds more like a head gasket. If it were the valve seals, the smoke would have a blue tint to it.
That is what was coming out of my tail pipes when I blew both of 'em on my 95 Trans Am.
Old 12-28-2004, 03:39 PM
right in that case it would be steam and not smoke,usually you can smell it when its oil.kind of a burning oil smell...as oppose to a steamed glycol odor
Old 01-05-2005, 03:16 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
could be but a head gasket would not stop smokeing and have other symptoms
Old 01-05-2005, 07:35 PM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
cars tend to smoke when they are cold.
Be glad its not blue, and drive it till something bad happens. or it gets more noticable.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 01-05-2005, 11:35 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
I used to have the same problem with my car. i wasn't sure exactly what it was, and even still i dont. Every time I would start it, whether it be cold or hot, I would get white smoke for a while. It would only last from about 5-10 minutes, and would eventually go away until i started to hit higher RPM's then it would come back momentarily. After a while of this, I took my car in to get a standard tune up. Got the oil flushed out as well. Then afterwards I got some Pennzoil Fuel System Treatment and poured that in my gas tank, and haven't had a problem since then. So try that if you want and already havent, and see what happens then. It wouldnt hurt anything doing so anyway. Well good luck, hopefully this helps some.
Old 01-13-2005, 08:57 PM
tank123 tank123 is offline
white smoke is water in combustion chamber probably head gasket. ta ke out spark plugs, the clean one is the cylinder that is leaking you can pressurise system to double check
Old 01-13-2005, 09:27 PM
Im going to chang the plugs this weakend hopefuly thats it. A head gasket is easer to change than valve seals and cheper too. Thanks for the info.
