Old 12-11-2004, 09:35 PM
Wind95 Wind95 is offline
95 tranny disengaging after stop
My 95's transmission disengages after a stop and jumps back into gear after pushing on the gas for a few seconds. It started out doing it occassionally but now is accurring at most stops. At all other times, the gears work fine.
The van does have 150k on it. I'm hoping someone may have a solution that won't include a new tranny. Thanks for the help!
Old 12-13-2004, 03:31 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: 95 tranny disengaging after stop
Check your fluid levels in the tranny... fill 'er up to the line and see if that helps.
Don't forget that you have to check the fluid with the engine warmed up and idling in "Park" on a level surface.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Old 12-14-2004, 09:25 PM
windstar4family windstar4family is offline
Possibly a cracked forward clutch piston. They are made out of aluminum and Ford had some problems with the piston exhibiting a hairline crack. The crack would allow fluid to escape thus letting the forward clutch bleed off. When you rev up the engine you are building more pressure and pushing more fluid to the piston until it reaches a point where it will apply the piston. This condition usually is prominent when the trans is warmed up which allows the aluminum to expand and thus creating an opening where the hairline crack is. Seen and fixed alot of these too in the dealership. Good luck and hope this helps.
