Old 12-11-2004, 07:41 PM
BlazinUP BlazinUP is offline
Unhappy 93 4.3 /w oil pressure guage/oil pump..somethin else?BAD
hi.....
iv got a 93 s10 4.3 w..141k..runns perfect...no bad sounds at all.
sounds like it should wether at cold start up or warm.
at start up the oil pressure guage is at about 50 at idle....
after it warms up it will fall to 10-15 at idle.
while driving the guage showes 30-40.
what im wondering is....why such the flux in reading@ different temps?
iv seen some guages that never go below 40.
anyone else have this happon?
is my oil pump.....guage bad.....i could use some help....PLZ
im running 5-30 castrol synthblend....if that helps.
thanks
Old 12-11-2004, 11:07 PM
rochma3 rochma3 is offline
Send a message via Yahoo to rochma3
Re: 93 4.3 /w oil pressure guage/oil pump..somethin else?
my 95 runs at about 15 to 25 at idle and at 35 t 40 while driving and dont have any problems
Old 12-12-2004, 08:18 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Your gauge sounds normal but the analog gauges on the 1st gens arent the greatest.... Look into replacing the sending unit (about 8 bux) They go bad as a matter of course... I have the same engine as you, typically it runs at 60 while cold, then drops to 20-25 at idle...
Old 12-12-2004, 11:48 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 93 4.3 /w oil pressure guage/oil pump..somethin else?BAD
Originally Posted by BlazinUP
hi.....
thanks
Completely normal.
Cold oil = thicker = higher pressure
Warm up = thins out = lower pressure.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-12-2004, 07:21 PM
i figured as much....again...as the engine never knocks or makes lifter noise etc.
ill get that sender looked at.....
and the cold thick oil...warm thin makes sence.
thanks for the input all
Old 12-12-2004, 07:46 PM
BlazerLT's Avatar
AF -Advisor
There is nothing wrong with your sender, don't replace it.
It is sensing properly, why are you going to swap it out for?
Common sense bro.....
Old 12-12-2004, 08:16 PM
i was wondering.....were the first gen guages...
faulty/inaccurate in some way?or just poor in quality.
then again teh truck is a 93....guess i should just be happy theres no noises...and the guage seemingly works.
Old 12-12-2004, 08:19 PM
BlazerLT's Avatar
AF -Advisor
All sending units are prone to failure in any year.
You only replace them if they are faulty. Some go for the lifetime of the truck, some last maybe 50,000miles.
Old 12-12-2004, 09:53 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
i have a problem kinda of what he is saying
in my 91 rite around 1000 a miles my oil gauge will drop from rite around 40 to 0 even though the stick says its in operating range and if you had the quart it goes back up to 40 would this be the sender
Old 12-12-2004, 10:01 PM
BlazerLT's Avatar
AF -Advisor
No , that is low oil level.
Old 12-13-2004, 05:59 AM
but still why if it is good on the stick because it is high in the operating range would the gauge read zero and be flucuating like making a turn equals zero then straiten out your up around 20-40
Old 12-13-2004, 06:10 AM
rlith's Avatar
Either weak pump being affected by sloshing or bad sending unit. Replace the unit and see if that works (only 5 bux)
Old 12-13-2004, 09:37 AM
BlazerLT's Avatar
AF -Advisor
Good luck getting to it though, it is a bitch to reach.
Make sure you have a good assortment of tools.
Old 12-13-2004, 01:34 PM
for what the sending unit is it gonna be fun to do i was thinkin it might be that because my that guage always seem to be wantin to mess w me because you would think if the stick is well in the range it would translate
