Old 12-11-2004, 06:59 PM
teggimann teggimann is offline
Question 96 Transmission Drain Plug
Hey, my sister needs her trans (auto) fluid changed on her 96 Taurus. I am unfamiliar with the vehicle and can't seem to find the drain plug anywhere. I'm pretty frustrated cuz it should be an easy job, but not if I can't drain the fluid.
Does anyone know where the trans drain plug is located?
Thanks,
Tim
Old 12-11-2004, 10:04 PM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
No drain plug on the tranny on these cars. You either have to pull the pan which is messy but gives you access to the filter, or you can use a suction pump through the tranny dipstick tube. I use a Liquidvac (http://www.liquidvac.com) and get about 1/2 the fluid out. I do this on both my '99 Taurus and '01 Windstar every year. It costs less than $36/year to do both (6 quarts each = 12 quarts x $3/qt).
Old 12-12-2004, 11:34 AM
Willyum Willyum is offline
Re: 96 Transmission Drain Plug
Altho messy, is smart to drop the transmission pan. There will be a layer of sludge in the bottom and Ford leaves a magnetic washer that needs cleaning. The filter change is easy and worthwhile. The gasket is usually reusable.
Old 12-13-2004, 09:06 PM
Re: Re: 96 Transmission Drain Plug
Thanks for the info-how difficult would it have been to put a plug on the tranny, right?
I guess I'll go after it that way then.
Tim
Old 12-13-2004, 09:07 PM
Thanks for the info, and liquivac idea.
Tim
Old 12-14-2004, 12:46 PM
Ford wants you to clean it out properly, to do that is to remove the pan, clean it thoroughly, clean the magnet. The fluid level is above the seam so when you loosen the bolts fluid will come out around it. Be prepared. When you're done you will be proud.
