Old 12-11-2004, 06:27 PM
Beater88 Beater88 is offline
Intake issues
Ok I will be doing my z6 in my rex
I have a 88 Si intake Manifold.
I will be going to obd1
I have a z6 Dizzy
I dont have a z6 manifold
Can I use my Si obd0 Manifold with obd1 injectors and no resistor box?
I want to use the Si Intake for smog issues as all the wires and map sensor and vaccum lines match the picture on the hood.
Also I have it already and dont have a z6 one.
Will the obd0 Map sensor work fine?
It is on the firewall insted of on the throttlebody
Will I have any issues with the VTEC and fuel delivery?
I plan to use a p28 ecu with a wire harness conversion.
Old 12-11-2004, 06:34 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Intake issues
You might have to change that obd0 map sensor, but I'm not sure. The manifold itself will work though.
Old 12-11-2004, 06:43 PM
Re: Intake issues
Humm...
If I did that I would have to change the whole intake as the IACV and purge control valve is on the throttlebody on the later models...
I was thinking that it might work because of all the people using the Fields VTEC controller with the obd0 stuff.
I wonder what the difference with the Map sensor is...
Old 12-12-2004, 06:46 PM
CRX-Crooks's Avatar
CRX-Crooks CRX-Crooks is offline
Send a message via MSN to CRX-Crooks
Re: Intake issues
I know the manafold will work
Old 12-12-2004, 09:00 PM
Re: Intake issues
Personal experence?
If you did this did you use the earler MAP sensor?
Old 12-13-2004, 10:20 PM
Re: Intake issues
Someone has to have used the 88-91 intake manifold and MAP sensors with obd1 injectors.
Please give me your input.
I will have the motor this week and hope to install it in the next weeks (xmas messes everything)
I still need a cheap p28 ecu, anyone?
Wiring conversion from obd0 - obd1?
