Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 12-11-2004, 05:57 PM
kungpowchicken kungpowchicken is offline
awd
Is there a 4wd, or awd eclipse
Old 12-11-2004, 06:08 PM
george536's Avatar
george536 george536 is offline
Re: awd
AWD gsx
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-11-2004, 07:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: awd
yes they make 1G Talon tsi awd, 1G eclipse gsx 1G laser turbo awd, 2G eclipse gsx, 2G talon tsi awd.
READ THE STICKIES!!!!! especially the one that says "FAQ read this BEFORE posting". ill even give you a link to it. http://www.automotiveforums.com/vbul...d.php?t=213325 that thread has a full listing of all the models of eclipse/talon/laser
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-12-2004, 02:27 PM
2of9 2of9 is offline
Re: awd
man, kungpowchicken must be a NEWBIE NEWBIE...im sorry, but that question he asked was a common sense question. he should gone to the FAQ threads..
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
