Old 12-11-2004, 04:12 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
2g mass air flow
what is the purpose of the honey comb looking part of the mafs? and can it be removed?
Old 12-11-2004, 04:37 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: 2g mass air flow
I believe the honey combs are used to "straighten out" the incoming air, so that the sensor can get a more accurate reading. The lower honey comb CAN be taken out, but it's not a wise thing to do unless you're running so rich you have no other option (in which case you should pick up something to tune with ) Usually, the car will run like shit if you take out the any of the honey combs.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 12-11-2004, 06:28 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
its designed to dirrect all uncharged air into a strait line, where it runs past the "hot wire" wich is basicly the reader for your maf. if you take out the honey comb the air wont be correctly messured
DSM geek
Old 12-11-2004, 07:31 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
just to clarify for people. taking out the honeycombs is a normal mod for 1G's but the 2G MAS is different so you should keep the honeycombs in it.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
