Old 12-11-2004, 07:55 AM
Kidd Ricky's Avatar
Kidd Ricky Kidd Ricky is offline
Send a message via MSN to Kidd Ricky
Question Stealth
i was wondering what the difference is between a Stealth ES and a Stealth RT.According to this http://www.team3s.com/FAQ-Specs1.htm ,there both the same
Recently Aquired '88 Celica GT
Old 12-11-2004, 11:35 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
They are not quite the same. The RT trim line had more standard features then the ES.
Resistance Is Futile (If < 1ohm)
Old 12-11-2004, 08:32 PM
Kidd Ricky's Avatar
Re: Stealth
Are they both awd or just fwd?
Old 12-11-2004, 08:52 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Stealth
All NA stealths and 3000GTs are FWD, only the RT/TT and the VR4 are AWD.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-11-2004, 10:28 PM
StealthModifier StealthModifier is offline
Re: Stealth
only real difference on the exterior are the taillights. and also the door panels and rear bumper.
Old 12-12-2004, 04:56 PM
crazy_quick crazy_quick is offline
Re: Stealth
isnt one sohc and the other dohc(r/t)
Old 12-12-2004, 05:14 PM
Re: Stealth
The ES has a DOHC, the base looks like the ES cept its the one with the SOHC, R/T has a DOHC
Old 12-12-2004, 10:40 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Stealth
Wrong, the whole entire body package is different. The headlight lids, snake eys, front bumper, rear bumper, tailights, door caps, side skirts, sail panels are all different between a ES and a RT.
The easiest way to put this is the ES is a base with a DOHC. The RT is the "luxery" edition.
Old 12-13-2004, 07:33 PM
Re: Re: Re: Stealth
u also forgot to mention that the piece that goes over the windows on the sides are different. the ES has it black while the R/T has it painted, but there different
Old 12-13-2004, 07:34 PM
Stealthee's Avatar
Re: Re: Re: Re: Stealth
No I didnt. What do you think sail panels are?
Old 12-13-2004, 07:37 PM
Re: Stealth
i thought sail panels were the pieces on the doors...?
Old 12-13-2004, 07:38 PM
Stealthee's Avatar
Re: Re: Stealth
Nope those are door caps.
