Old 12-11-2004, 02:17 AM
minessa minessa is offline
Send a message via MSN to minessa
Question 93 honda accord
I was hoping someone could help me out. I have a 93 honda accord that will only run sometimes. If it's too hot outside, it won't start (sometimes it'll start after it sits a while, but not always) I put a new alternator & battery in it & it worked for 1 whole day & now the tester says the battery's dead. could it be a relay? Any suggestions appreciated.....thanks
Old 12-11-2004, 02:45 PM
J00ky J00ky is offline
These are the possible problems you might have, according to the symptoms you described.
1. Engine hard to start when hot
-possible problems: Air filter clogged
Fuel not reaching fuel injection system
corroded battery connections (especially ground)
2. Battery will not hold a charge.
-possible problems: Alternator drivebelt defective or not adjusted
properly.
Battery terminals loose or corroded
Loose, broken or faulty wiring in the charging circuit
Short In vehicle wiring.
Internally defective battery.
I got this from a complete repair manual for 90-93 Accords. I hope it sheds a bit of light on your problems!
Old 12-12-2004, 12:02 AM
mpumas mpumas is offline
Re: 93 honda accord
Sounds like a main relay for the reason it doesn't start when hot outside. The reason the battery is going dead is harder. Need to find out if there is a load on the batttery when everything is turned off. Need to find out if the alternator is actually charging the battery. Some things can be determined with a light bulb and wire. Other things will require a cheap Radio Shack volt/ohmeter.
Old 12-12-2004, 07:48 PM
BigRed BigRed is offline
Wink
I too have a 93 EX with simular problem. I replaced the MFR (main fuel relay) $66..dealer not it. If you hear the fule pump run for 3-5 sec after you turn on key this is not your problem..open fuel cap and have someone turn the car on. If no fuel pump this may be problem.
Next is spark. Take you distributor cap off and see if its all caked up with crud on contacts and rotor. You rotor and cap are suspect. If it looks good then it is the ingnitor and or coil. Look up specs on this fourm and test coil first...Good luck!
