Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-10-2004, 06:21 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Jingle
Recently I replaced shock/struts on my car, now when I go over a bump on the driver side of the car I hear a jingling noise (like a washer and bolt sound) that only happens over hard bumps. Could it be something in the strut boot, when I took it off the rubber bushing was pretty beat up, but I still threw it on figuring I'll replace it later. I know that tracing sounds it difficult over the internet, but I'm just asking on some ideas of what it might be.
I appreciate any help.Thx.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 12-10-2004, 08:15 PM
Adhesive STP Adhesive STP is offline
well it is near christmas, maybe its santa?
Old 12-10-2004, 10:25 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Jingle
dashing through the snow... in a 300 horse stang... past the rice we go... laughing all the way!
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 12-11-2004, 09:18 AM
andrewespo's Avatar
Re: Re: Jingle
"Past the rice we go"
Old 12-11-2004, 09:39 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Jingle
What struts did you use? when I installed my Lakewoods they came with shims to go between the base of the strut and the strut mounting bracket on the spindle. Not using this shim will allow for the strut itself to pretty much free float in it's mount.
Also another thing to check would be the swaybar end links. Make sure they arenot broken and are tight.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-11-2004, 10:05 AM
andrewespo's Avatar
Re: Jingle
I installed KYB GR2s'. The front struts didn't come with any shims, only a nut.
Old 12-12-2004, 09:57 AM
andrewespo's Avatar
Re: Jingle
Found the Jingle and it wasn't Saint Nick, it was the rear brake line that goes over the differential to both drums, it came loose and was banging on the differential.
Thx for input guys.
