Old 12-10-2004, 05:05 PM
eclipsekid eclipsekid is offline
Creaking sound from steering up front
I'm starting to hear (and feel) a creaking noise (kinda like dry metal rubbing together) coming from my steering somewhere up front. I hear it when I turn the steering wheel stopped or when driving, it doesn't matter. It seems to be getting worse. Anyone experience this? Is it a simple matter of greasing up some joints? If so, where are the grease nipples on the front steering linkage? This is only my guess as to where this horrible sound is originating. It's getting so bad, that I can actually feel the creaking on the front floorboard. Any help would be much appreciated.
Old 12-10-2004, 07:43 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Creaking sound from steering up front
it could be your outer tie rod ends. i dont know if the stock ones have grease fittings but if they do it should be on top of the tie rod end which attaches to the wheel spindle
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-11-2004, 01:31 AM
BaXuyen BaXuyen is offline
Send a message via AIM to BaXuyen Send a message via Yahoo to BaXuyen
I seem to be having the same problems, but my seem to be coming from the back. The noise stop every time I step on the brake. So I'm thinking it could be something related to my brake ( I just had it change about a month ago, when they did it one of the bolt was broken because of rust and old. they did replace it with another bolt though). That and the fact that some one real end me just recently. They took it to the shop to get the rear fender repaint, and said they didn't found anyother problems. So If anyone know of some of the stuff I could check to see what's wrong with it. Please let me know I'm also going to a mechanic to see what's wrong with it.
Old 12-18-2004, 04:05 PM
Well found out the problem. The noise was coming from my balljoints, which I took in to get the recall done today. The mechanic showed me how bad they were. They were horrible. A few more weeks and I probably would've had my wheel fall off!
Old 12-19-2004, 01:52 AM
Recall? Is there a recall for the ball joint on 91 eagle talon?
Old 12-22-2004, 02:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
As soon as I saw the original post I knew it was balljoints. The recall is on the 2Gs and covers the balljoint and the Lower Laterall Link it is attached to. Just a reminder to all 2g DSMers to have the balljoints checked, even if the recall was already done! I have to replace mine every 40k miles or so. 1Gers should check their shit out too, have to be safe above all else.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
