Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-10-2004, 04:50 PM
th_james2003 th_james2003 is offline
slick sizes
well i have 22.0/8.0 i think i need a taller slick because i get good 60'' ft times, but my tires squeel like there peeling out. i was wanting to know if anyone has used a taller slick on ther civic. now mine it lowered a little but can be adjusted higher. let me know thanks.
Old 12-10-2004, 10:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Do you warm them up good before you race? Also using a taller tire is going to change your gear ratio as well too, which will change your trap speed and ET. You need to consider this too when choosing tire sizes, the bigger the tire the taller the ratio.
Old 12-11-2004, 02:57 AM
Re: slick sizes
well i think i do i mean i get them to smoken pretty good until the slick pulls me through while my e brake is up. here is a video of me at the track listen to the squeeling, also i have a b16 tranny how much do you think my trap and et will change with a 24'' slick. http://www.greenvillesource.com/vids/HonduhVSGT.mpeg
Old 12-11-2004, 03:39 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: slick sizes
give us your setup, how much hp you making ? what are you launching at ? wheres your peak hp at ?
Team Lonely Drivers
Old 12-12-2004, 12:40 PM
Re: slick sizes
well i have a built b20. the only thing stock is intake manifold,cams,and crank.on a 75 shot now.in that video i was on a 50 shot. i have not hade a chance to dyno the motor with the nitrous. i was going to but my bottle was empty, long story. any way i launch at 6500 rpm on the bottle. my peak hp is at 7800 rpm.
Old 12-12-2004, 02:16 PM
Re: slick sizes
what are your 60' ft times ? how about 1/4 times ?
are you spinning the slicks anytime down the track other then the launch ? also on the launch, are you still spinning tire when you hit second ?
your run looks good, i dont see any problem with it traction wise.
Team Lonely Drivers
Old 12-12-2004, 10:54 PM
Re: slick sizes
well i would like to see my 60'ft go down some. i get about a 1.8 average 60'ft time. i have hade lower like a 1.76 or something. but my friend has the same size slicks and its getting 1.6 60'ft times so.
Old 12-13-2004, 05:26 AM
Re: slick sizes
1.8 60' times arent bad. have your tried playing around at where you launch at to see if you can go better, like higher rpm or lower ? what tire pressure r u running on the slicks ?
Team Lonely Drivers
Old 12-13-2004, 10:21 AM
Re: slick sizes
well i have tried different tire pressures and i have found that 10 to 12 pounds is best for me. i launch at 6500 rpm on the bottle also with stock axles from auto zone, i m afraide that they will break.
Old 12-13-2004, 02:22 PM
Re: slick sizes
have you tried different rpms ? its really a boring matter to do, you need to choose a bunch of rpms and vary the tire pressure at each of those rpms. kinda like taking note.
i think if you do go to 24" then you will break those stock axles.
but i also think if you want a quick way into the 1.6 60' then 24" slicks should do it. but like mentioned above, it will change yoru et and mph.
Team Lonely Drivers
