Old 12-10-2004, 01:40 PM
CORE402's Avatar
CORE402 CORE402 is offline
Traction bars
So now that I have Horsepower, a bad a** transmission, and a rear end with posi and some deep gears would traction bars really help out my ride? I stomped the gas yesterday for the first time! WOOOO! The car hauls. It peels out from a 15mph roll on! I really would just like to know where I should go from here?
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 12-10-2004, 03:17 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Traction bars
Well if u have a lot of hp,traction bars will help a lot.But I would look into getting some other suspension parts all so, like new polyurethane bushings and shocks.
Old 12-10-2004, 10:08 PM
blackgloves's Avatar
blackgloves blackgloves is offline
Re: Traction bars
Subframe connectors(kenny brown double diamond) Lower control arms(BMR). Go with some springs that are for drag racing. Make sure you do your home work when you get the springs and shocks. They have to work together. If not, you're defeating the purpose on your launch. Oh and a strut tower brace (BMR)
Old 12-10-2004, 11:18 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Traction bars
i believe its hotchkis that makes a complete suspension kit that works well. ive dealt with bmr a lot and am very satisfied, they have everything you could want and some stuff that you wont but will get anyways. i would say control arms, torque arm, trac bar, and atleast a rear sway bar upgrade.
*Better power-to-weight ratio than a C6 corvette*
Old 12-11-2004, 03:45 AM
CORE402's Avatar
Re: Traction bars
Remember here I have a '73 Camaro with a front frame and rear leaf springs. I dont have that fancy smancy four-link rear suspension lol nor strut towers.
1973 Camaro
AFR 195cc heads
TH350
Old 12-11-2004, 02:09 PM
Re: Traction bars
prolly would have been good to know that in the beginning. ofcourse it prolly would also have been good to read your sig in the beginning. im just gonna pretend like non of this happened.
Old 12-11-2004, 04:09 PM
CORE402's Avatar
Re: Traction bars
LOL! That was great. Yeah I am the muscle car freak here in this forum. EFI??? AHHH I DO NOT ACCEPT CHANGE!!!!!!!!!
1973 Camaro
AFR 195cc heads
TH350
Old 12-12-2004, 12:58 AM
69ralleygreen 69ralleygreen is offline
Re: Traction bars
core 402 how much horse power do you have what gear in the rear and what tranny ive had many camaros i can recommend many things according to whats in the car...mike
Old 12-12-2004, 01:19 AM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
i have alot of spohn racing adjustible suspension parts on my car, i really like 'em and would recommend spohn if u want suspension parts
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 12-12-2004, 04:42 AM
CORE402's Avatar
Re: Re: Traction bars
The car is putting out about 350hp, has a 3 speed TH350 and has 3.73:1 rear ratio.
1973 Camaro
AFR 195cc heads
TH350
Old 12-12-2004, 08:54 AM
Re: Traction bars
for your car with that gear you really dont need any thing but you can add two cheap things small nos kit like 100hp shot if you do add the nos then you can add traction bars you do not need frame connectors with 350 hp my 355 in a 73 camaro made 550hp no frame connectors only traction bars with the snubber touching the leaf spring so when you hit the gas the bars dont have to move alot ...mike http://www.jegs.com/cgi-bin/ncommerc...37&prmenbr=361
Old 12-12-2004, 01:11 PM
CORE402's Avatar
Re: Traction bars
Thanks a lot 69ralleygreen. I am planning on running with what I got for a little while. Someday I do plan on actually going through my engine and tweaking some things like new pistons, AFR 195s or porting the camel humps I have in there now, nitrous, etc. I have my own I ideas of what to do but I just wanted to see what others thought I should do. It is always good to get outside opinions on a situation, they might see something you have overlooked or plainly know more then I do.
1973 Camaro
AFR 195cc heads
TH350
Old 12-12-2004, 01:15 PM
Re: Traction bars
good luck...mike
Old 12-12-2004, 01:56 PM
CORE402's Avatar
Yeah those are the exact same traction bars I was looking into for my setup.
1973 Camaro
AFR 195cc heads
TH350
