Old 12-10-2004, 12:38 PM
c formaldehyde c formaldehyde is offline
Send a message via AIM to c formaldehyde Send a message via MSN to c formaldehyde
dwnshift rpms drop and dies
ok well first of all ive noticed that just about every thread in here is about s-10 problems. why buy one then? well my brother has an s-10, it needs a tune up badly. a while ago we had to replace the battery (about a month ago). also, someone put the spark plugs in backwards, or in the wrong order, so it got fucked up and we had to change them. well now everytime we're driving in it, and he is downshifting when coming to a stop, the rpms drop to about 500 and the truck nearly dies. it has died before as well. i forgot what year it is, but if there is any suggestions it would help a lot. thanks
Old 12-10-2004, 12:46 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: dwnshift rpms drop and dies
your right every thread in here is about s 10;s and s 10 problems, thats because when you enterd the sight you clicked on chevy then s 10 taking you to a forum spicificly for the chevy s 10 (and gmc sonoma and s 15) truck.... as for the porblem with the truck im sure someone will have an idea as to what it is as i do not
Old 12-10-2004, 09:35 PM
OverBoardProject OverBoardProject is offline
Banned
If someone messed up with the wires order it might still be wrong.
What motor does it have? someone will tell you the proper order.
If you look on the other forums you'll see as many problems with every other type of car, and truck... with the exception of hotrods, and that's because most rodders either know their cars, or have very deep pockets.
even then they have the weirdiest questions
Old 12-13-2004, 12:27 PM
well i know i went to the s-10 forums. i was just saying that the s10 forum is mainly about problems. well the truck is a 95 s10. completely stock. its just been ridden really hard and probably needs a tune up.
Old 12-14-2004, 09:03 PM
xtremetrk xtremetrk is offline
I know on the 94-newer trucks the stock spark plug wires are labeled. I have a 99 4-banger. If you go to a autozone or advanced auto parts they have a s-10 manual. It has alot of useful info but it still can be vague. I checked my s-10 book and it says for the 4-banger the numbers should be starting from the front of the motor is number 1 and to the rear of the motor is the fourth ( in order 1 to 4). For the six cylinders the plug wire order is on the right side of the engine it goes from front to back 1-3-5 and on the left front to back 2-4-6. If you need any more information please feel free to ask.
Old 01-02-2005, 05:41 PM
BikerScooter BikerScooter is offline
Angry Low idle & dying
My 85 - 2.5 does the exact same thing...from what I've read it seems to be associated with the IAC motor (Idle Air Circuit) found on the fuel injection system. I have yet to replace this, maybe someone else has and can confirm?? If by chance I get some free time & $$ , I'll swap it out and see if it goes away. Most spare cash is being used to finance my HO 305 & TH350 swap scheduled for later this spring.
