Old 12-10-2004, 10:28 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
vette servos
Hello everybody,
I have heard very mixed opinions on installing corvette servos into our 4l60es. Some claim it ruins the transmission, while some people say it will actually save it.
I don't know who to believe, but I trust you guys. Pretty much everyone agrees that it gives sweet shifts, I just want to know if it'll turn bad in the long run.
Old 12-10-2004, 06:25 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: vette servos
They don't ruin the transmission.... They keep applied pressure more is all. About a 10 minute install. I run a vette servo, B&M Transpak, and a B&M Electronic shift improver... Very Very happy
Old 12-10-2004, 08:25 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: vette servos
Would that help a 91 w 161000 miles on it and how hard of an install because i saw they only run for about 20 bucks and that sounds pretty good for the money involved?
Old 12-10-2004, 08:27 PM
rlith's Avatar
Re: vette servos
Pretty easy, simply pop off the cap, (pull the retainer ring) pull the old servo, put the new one in..
Old 12-10-2004, 08:43 PM
chcknugget's Avatar
Re: vette servos
Thanks for the advice,
I already bought my servo, it was only $12.96 on ebay. I'm about ready to put it in but wanted to know a few more opinions first.
Right now I have the hypertech firm stiffness and shift point adjustment on. I've heard that this coupled with the servo is a great setup.
Seems like everyone thinks the servo is the best mod for your buck kinda thing. Some have said you need to move your transmission so you have enough clearance to get the pin out. However It seems like everything can come out one at a time with no problems.
Rlith, when you are adding ATF fluid do you pour it through your dipstick hole?
Old 12-10-2004, 10:21 PM
rlith's Avatar
Re: vette servos
Yes, through the dip stick hole... But you should lose less than a cup of fluid changing the servo
Old 12-11-2004, 10:37 PM
chcknugget's Avatar
Re: vette servos
How hard is it to press the cover in and take out the retaining ring? I'm planning on using the but end of my factory lugnut wrench to push the cap in. It seems like none of my projects end up being as easy as they should be...
Old 12-12-2004, 07:24 AM
rlith's Avatar
Re: vette servos
Here's a good how-to
Old 12-12-2004, 11:51 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: vette servos
Where?
I might do this myself.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-12-2004, 12:09 PM
rlith's Avatar
Re: vette servos
Shit, forgot to paste it.... http://sethirdgen.org/servo.htm
Old 12-12-2004, 02:11 PM
chcknugget's Avatar
Re: vette servos
O yeah, I jave soem good links too. These sites say you may need to move the tranny when you do it. Is that true rlith?
[link]http://www.impalassforum.com/tech/drivetrain/Vette_servo/transgo_servo.htm[/link]
and
[http://sethirdgen.org/servo.htm[/link]
Old 12-12-2004, 02:12 PM
rlith's Avatar
Re: vette servos
I've done 6 or 7 of these for friends and at worst I've just had to push it over with a prybar
Old 12-12-2004, 02:16 PM
chcknugget's Avatar
Re: vette servos
crap, sorry about the bad link;
http://www.impalassforum.com/tech/dr...nsgo_servo.htm
Old 12-12-2004, 05:03 PM
BlazerLT's Avatar
AF -Advisor
Re: vette servos
Yea, I found both of them via google.
Deems to be not to bad of an install.
Old 12-17-2004, 06:33 PM
chcknugget's Avatar
Re: vette servos
My uncle designs performance torque converters (and is working on some future corvette tranny) for GM so I figured he'd be an excellent source of insight about vette servos. I have read many conflicting arguments over whether servos are bad, neutral, or actually good for your tranny. I sought truth and this is what he wrote back:
Originally Posted by Uncle Shawn
First of all, a post 1993 4L60 transmission (4L60E) would try to correct for the quick shift by reducing pressure at shift. If it couldn't correct, you would get a service engine soon light / trouble code. The servo/accumulator limits or softens the pressure applied to the clutch pack during the shift.
Second, a faster shift is easier on clutch packs (less energy/heat into the clutch pack & oil). However, you are spinning a lot of inertia with engine / converter. So at a shift, there is engine torque + inertia torque. Inertia torque = (Engine & Converter Inertia x deceleration). The input
shaft / turbine shaft is one of the weaker links in the transmission. You can chirp the tires at every shift until the turbine shaft snaps.
I thought this would be interesting to know. Although I believe my uncle and have little knowledge about transmissions, I'm not too concerned about breaking my turbine shaft because I don't try to chirp my tires. I have the hypertech firm stiffness already installed so the computer wouldn't correct my shift pressure (if that was a problem).
I have my vette servo and plan on installing it over next week. I got some VERY comprehensive pictures and instructions (more helpful than the links) from the friendly ebayer who sold me my servo and I plan on posting them soon.
