Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 12-10-2004, 08:04 AM
cindaroo cindaroo is offline
wanna be home for xmas,
i rplcd the alt belt and disc the batt cable chnging it, now it won't run. It did prior to disc the batt cable. It will run as long as i put gas in the carb and the filter isn't clogged, i ck'd it, please any ideas trying to get it fixed so i can get home for xmas, stuck in nc. please reply to my email at [email protected] thanks...
Old 12-12-2004, 02:42 AM
Re: wanna be home for xmas,
please reply to my email [email protected]
Old 12-12-2004, 09:46 AM
Re: Re: wanna be home for xmas,
does anyone know where i can get a schematic on a 84 to replce the fuel pump?
Old 12-13-2004, 05:56 AM
please help, 12 days till xmas, trying to get my fuel pum p chngd to get home
Old 12-17-2004, 09:44 AM
can anyone give me step by step or a schematic of an 84 gas tank? I need to remove it to rplc my fuel pump.. pls reply to my email...still stuck in n.c......
Old 12-17-2004, 11:37 AM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
you have to raise the whole car at least 12-15 inches off the ground....the fuel pump is inside the gas tank which is located under the car, between the 2 seats. All you really need to do is undo all the hoses on the back of the tank, take off the braces that hold it in, and drop the tank out....being carefull not to spill any gas on you or your helper in the process. There is a collar that holds the sending unit in place at the top of the tank, just turn it counter-clockwise, i believe, and pull the sending unit out. Then replace the pump and always replace the sock filter too....then reassemble everything.
Old 12-18-2004, 08:11 AM
grgoyl86 grgoyl86 is offline
I guess you didn't get my email.
I did a little search, and found this: http://www.geocities.com/MotorCity/G...uel-pump.html\
Hope that helps . . .
Old 12-30-2004, 08:01 AM
does anyone know how to exactly take the gas tank out on my 84 to rplc the fuel pump?
Old 12-30-2004, 08:31 PM
Try this: http://www.geocities.com/MotorCity/G...fuel-tank.html
And this one: http://www.geocities.com/MotorCity/G...fuel-pump.html
Good luck.
