flickering lights
Anyone find a solution to a flickering light problem? Both interior and exterior lights flicker while driving. Have had a new alternator installed, performed the tech bulletin service with voltage regulator ground screw,have taken to 2 dealerships and have had no success with fixing the problem. Suggestions or remedies?
maintlead |
dunno sorry, but mine do it also. just interior lights. exterior lights are fine. what might cause interior lights to flicker.
Re: flickering lights
I was told it is the multifunction switch.I have the same problem
Have you replaced your battery? You may have a weak/dead cell in the battery. I had same problem, but voltage regulator ground screw cured my problems. Batty died shortly thereafter from all the flickering beforhand not fully charging the battery. So $5 screw and $60 battery and back in business!!
the pcm/bcm? could be the culprit. My running lights went nuts on my wife while she was driving and a cop coming from the other direction pulled her over because he thought she was warning other drivers! Dumb #SS. Took it in and it took 2 days and only $300 dollars later and they found the problem. The PCM/BCM, can't remember, needed to be replaced and the problems quit. The ac even quit while this was happening. 3 months later the pcm/bcm needed new programing and the security light is now off. Dang car wouldn't start some times.
Also if you notice hesitation, loss in power at low rpms and bad gas mileage then replace the catilyic converter. I had it done with a hi flo one and the cars screams. |
Temp Gauge
Well i changed the temp sending unit again only this time i got the one with the new wire and plug and now it works so i guess it was the wire.(good call)
bcm
i had headlights,breaklights,interiorlights,glovebox lights flicker, radio locked, high beam faliure, security, lights.and only when car was warm. the service manager at the dealer had every one come and look no one had seen this before. tturned out to be bcm. $ 300.00 $150 for module,$150 for install
Re: bcm
Thanks, 'll have the dealership give it a try. |
