Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 12-10-2004, 07:39 AM
eric bicking eric bicking is offline
dash light dimmer & 4 ways 96 tracker
I have no dash lights. I suspect the dimmer switch, however, it has 3 wires, black I will assume is ground, the other two "red" wires are hot.
Is this normal.
Also have no four ways.. Switch will cut out the turn signals, but wont flash. I can find only one flasher. Do the 4 ways and turn signals route to the same flasher? Im guessing bad switch , but this is looking expensive. Any quick ,easy tests? Thanks
Old 01-17-2006, 10:47 PM
gumby_ct gumby_ct is offline
Re: dash light dimmer & 4 ways 96 tracker
I looked at a 1996 (93k/mi.) today that the turn signals would NOT work with the flasher button down but the flasher did NOT work either. Have you found a solution yet?
Also this gem had a milky substance on the bottom of the oil filler cap. I was wondering if this is normal for Trackers? It seemed to run ok & had good power. Any thoughts?
Thanks,
Gumby_CT
1998 Chevy Tracker 4dr, 4wd, auto,
1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi.
My other car...in need of repair it won't start any longer
1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav)
