Old 12-10-2004, 02:32 AM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
beware of the mechanic
I am stuck. I dont know if i should go after the mechanic who worked on my car last. He did a headgasket and timing belt and within a week my car was running like crap again. I decided to pull the motor and try to build the car alittle and found out that all of the work he did was wrong. I could take the timing belt off by hand without releasing the tensioner. I could also see that the lower cover was broken off and never replaced and the cam angle sensor was cut and spliced back together when there was a plug to disconect it not 6 inches down the line. there are many bolts and fasteners missing, and my new mechanic said that he had seen better work performed by a 3 year old with a hammer. I was also told that the problems I was having were directly related to the fact that the work was done so poorly. I mean come on. a blown headgasket leading to complete fatal meltdown. I know it is possible but not to the point of damage that was done. Atleast thats what my new mechanic says....... What would you do? Would you make the old mechanic pay for the thousands of dollars of work that now must be done, Or would you cut your losses and move on?
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 12-10-2004, 03:12 AM
by the way the mechanics name is dana aka chip and he is working in the skagit county area of washington. BEWARE!!!!
Old 12-10-2004, 07:54 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: beware of the mechanic
Umm... Hellooo! Is there anything going on inside that seemingly waste of space, you call a head?
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-10-2004, 12:50 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
i'd say suck it up, be the dsm'er you are, and rebuild it yourself. thats what comes along with our cars, if your not upto it you should just move on. these are the things that make having a dsm fun. if you want a reliable car with little maitnence and you like shelling out $$ for somone to fix everything for you there is always smiths honda across the street from burlington mall..
DSM geek
Old 12-10-2004, 01:02 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Ok, if no one ever goes after mechanics like this then what would be their reason for not doing it again. I mean come on guys. Yeah go after him! Take his ass to court. I think you gotta pay like $60 or something to take him to civil court or just give some lawyers a call. I'm pretty sure they'll talk to you for free and tell you what's up. These people shouldn't be aloud to get away with this shit. You'll be doing a lot of other people a favor too that wont have to get screwed.
You could also report him to the BBB and I'm sure there's other stuff you could do too.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 12-10-2004, 02:12 PM
InnerDragon103's Avatar
InnerDragon103 InnerDragon103 is offline
Send a message via AIM to InnerDragon103
Seriously man, take him to court! THere is a difference between, resolving mechanical problems yourself (uh "sucking it up like a DSM'er??") and then getting your damn money back for the VANDALISM that mechanic commited on YOUR car. If that had happened to my car, i would have taken a tire jack to his ass, ya know???
Old 12-10-2004, 02:38 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: beware of the mechanic
You might be the only person that thinks blowing a headgasket and then getting screwed out of hundreds of dollars by your mechanic is fun.
I would talk to the shop and see what they are willing to do about it, if they give you the run around I would take them to court. You never know, they may be willing to fix their mistakes (I would hope )
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-10-2004, 06:56 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
i wouldnt let them try and fix it it sounds like they'll just fuck it up worse. get a quote to fix it from a respected shop (somebody from near there might me able to tell you one) and show the oldmechanic the quote tell him you're pissed and that you want him to pay for the damages to your car. if he cooperates good, if not take him to court.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-10-2004, 07:47 PM
just so you know I am already in the process of rebuilding a 6 bolt MYSELF..... I will be taking chip to court over this. my only hope is that it dont reflect bad on on chris. Chris owns the shop. He is the best "one of" man I know.
Old 12-10-2004, 08:01 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
some lessons are hard learned.
i bet you will never have that problem ever again
Old 12-11-2004, 09:36 PM
DreDay1984 DreDay1984 is offline
Banned
um what kind of shop is it? cause i wouldnt be caught dead going to some bs no name shop, only specialty or mitsubishi ill let work on my ride
