Old 12-10-2004, 12:54 AM
Canabalooza Canabalooza is offline
weird problem
so i was driving home from work today it was raining and i was going about 40 in 3rd or 4th around a slight bank to get off the free way. it seemed that around 2000 to 2500 rpm it lagged if i pushed it alittle it would rock back and fourth and it was gutless but if i floored it it would pull out and act normal untill i slowed below and tried again. i turned my car off at a light and back on and it didnt do it anymore. any ideas im worried and i dont have money to fix it if it breaks.
Old 12-10-2004, 01:28 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
What do you mean it rocked back and forth? Kinda like it sputtered a little or somethin? Sounds like either an ignition or fuel problem to me. Any codes?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-10-2004, 07:03 PM
Re: weird problem
yea it sputtered back and fourth i guess it was sputtering but it would be like rearrearrearrear and then id floor it and it would accelerate again. another thing is that when i would rock it would constily loose speed even though i never moved my foot. i have code 1 but thats cause i cant get it to go away even after i changed out my 02 sensor twice.
Old 12-10-2004, 07:19 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: weird problem
check and see if your dizzy rotor is tight.
Old 12-10-2004, 11:56 PM
skotman's Avatar
skotman skotman is offline
Re: Re: weird problem
and check it soon before the damn screw flies off and breaks the thing :P
Old 12-11-2004, 12:30 AM
Re: weird problem
which screws the one on the outside? or do i have to take the black outside off im new to this stuff.
Old 12-11-2004, 01:17 AM
Re: weird problem
tried to wiggle it its solid as a rock
Old 12-11-2004, 01:25 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: weird problem
just a quick q, wut was u'r fuel level at?
Old 12-11-2004, 01:29 AM
Re: weird problem
full
Old 12-11-2004, 01:36 AM
mattio781 mattio781 is offline
Send a message via AIM to mattio781 Send a message via MSN to mattio781 Send a message via Yahoo to mattio781
Re: weird problem
what kinda car you got, si dx, my si does the same thing also, acts gutless and ill floor it and it'll go, not quite as bad as yours though
2006 Ion3 quad coupe,Polar White,Black Leather, 2.4L Cai, Saturn Motor Sports Thermal Research Cat Back exhaust system, 15%window tint, 12" jl w3, rips some shit up!!!
Old 12-11-2004, 10:54 AM
Forunn Daberator
Re: weird problem
take the three screws off the dizzy cap, the rotor is under it.
Old 12-11-2004, 11:48 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
fuel filter?
Old 12-11-2004, 12:16 PM
Forunn Daberator
Re: weird problem
Fuel filter will usually mess up flow at higher rpms insted of lower rpms
Old 12-11-2004, 01:17 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
I had that problem in my 92 Si. It was my spark plug wires. They were getting moisture in them. they looked perfect to me, but I swapped them and the problem was gone.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 12-12-2004, 02:55 AM
Re: weird problem
i have an 89 si crx im going to change out my plugs and wires and check my dizzy tommorow hopefull it wont happen anymore. it was raining out so it might be moisture.
