Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-10-2004, 12:15 AM
VetteZR1guy VetteZR1guy is offline
1998 Suburban 2500 series
Having hessitation problems at 60-80mph...
Replaced
Sparkplugs
Wires
Rotor
Rotor Cap
Vehicle doesn't hessitate constantly! Cuts out every so often at various mhr...during eccelloration vehicle performs well....Any Ideas?
Vortec V8 350 5.7ltr
Old 12-11-2004, 09:54 PM
SGHETTO SGHETTO is offline
Maybe you should have your map sensor tested. If it's ok then it sounds like you may have a fuel pressure problem. it probably time for a new fuel filter or fuel pump. Also you could try to clean the fuel system with a good fuel injector cleaning additive. I had a similar problem once .I put in the cleaner and filled up with 93 octane.after a taking the long way home she idled fine.Yet another suspect in hesitation and power loss cases not to be overlooked is your catylic converter(s). Hope this helps.
