Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 12-09-2004, 11:23 PM
rep rep is offline
water in driver side floor 323i
My '98 BMW 323i convert has developed a water leak seems to be comming on drivers side under rear seat then onto floor... no visible leaks from top or window area.. Suspect a "drain" line clogged up.... where are these located?
Old 12-11-2004, 02:38 AM
93gsxracer 93gsxracer is offline
Re: water in driver side floor 323i
Have you recently had a window regulator replaced? There is a vapor barrier behind the door panel that will cause a major water leak if not sealed properly.
Old 12-11-2004, 09:50 PM
rep rep is offline
Nothing has been done with vapor barrier in door/window.... Have had this vehicle for about two years with no problems.... this just started all of a sudden....
water seems to collects under the rear seat first and then the floor gets wet....
Old 12-12-2004, 01:02 AM
Mark E M Mark E M is offline
Pull the rear seat out, saet and seat back. check carefully around supports for water tracks. Your rear window seal may be leaking....Later mark.
