Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-09-2004, 08:03 PM
mclemmon mclemmon is offline
Turns over but won't start
Hello, thanks in advance for any help. I have a 2000 durango, the turn signals had been acting up and they finally quit. Changed out the relay near the emergency brake and all was well. The problem is now it won't crank, it'll turn over great but not start. Don't know if the turn signal repair had anything to do with it or not. However, the wife did come in that night and said the the durango had acted strange, like it cut off or lost power for a couple of seconds. Anyway, any help would be greatly appreciated. If it was for this forum I wouldn't have know about the hidden relay on the turn signal.
Mark
Old 12-09-2004, 08:41 PM
fasteddy69 fasteddy69 is offline
Turns
Could be fault in fuel inj. system, fuel filter plugged, battery discharged, no gas, battery terminals loose or corroded, Fuel pump, ignitions sys. problems such as moisture or damage, spark plugs, starting circuite wiring (I would take a look at that one) especially at the wiring around the area you did your fix.
Old 01-09-2005, 12:52 AM
omanj79 omanj79 is offline
Send a message via ICQ to omanj79 Send a message via Yahoo to omanj79
Re: Turns over but won't start
mine was cutting out and acting like it was not getting any fuel turn over fine but would not start after a few mins it would start did that a few time took to the shop couldn't find anything wrong drive it home started doing it again got under the hood looking and the it was the ingition coil the next day the check engine light came on took to the dealer they said it was the coil tommorrow going to replace the coil wires cap and key and going to see how that works let you know
Old 01-12-2005, 12:51 AM
cbreeze191 cbreeze191 is offline
next time it dies check in the odometer location sometimes a fault code will come up, if so what is it
Old 01-29-2005, 03:13 PM
Smoke24 Smoke24 is offline
My '99 did the same Friday morning, would not start after it ran just fine Thur. night. I can't figure it out either but it's really too cold and wet here in AL to do much with it right now. I had made no repairs but it has had a bad output speed sensor for over a year. It would just hesitate in shifting once in a while but seemed to get better gas mileage with it broke. Mine is the 5.9 and I had installed a Jacobs ignition and K&N filter about 4 years ago. I could use a few ideas to look for too.
Got it fixed since we had a pretty enough day Sunday to tinker with it. Mine had a short in either the coil or the control box for the Jacobs ignition system. Hooked it back up to the factory coil and it fired up and runs just fine.
