Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-09-2004, 07:37 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
will my 1.8 head fit on a 2.0 engine block
i need either a 1.8 engine or find out if i can use my 2.0 block with my 1.8 head why would i do this be cuz i scraped the 1.8 to 2.0 engine swap to much time and money to do something like that so my new plan is to just fix the 1.8 and my block is cracked on the 1.8 so if any one knows were i can get a 1.8 engine that would be great or if i can use my 2.0 block with the 1.8 head the 1.8 is out of a 93 eclipse the 2.0 is out of a 91 talon what should i do can any one help me and finding a 1.8 engine is near impossible and a new one cost like $1800 not the kinda money that i wanna spend on the engine and i got an enigine out of an automatic but it won't work in a five speed so the engine needs to be out of a five speed
Old 12-09-2004, 08:24 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: will my 1.8 head fit on a 2.0 engine block
i can sell you a 1.8 block if you get a balance shaft eliminator kit for it. it spun a bshaft bearing and messed up the bearing journal, but the rest of the block is good. i would like $200 you would have to come get it or pay shipping im located in lancaster pa. i probably also have any other 1.8 parts that you need. pm me if you're interested.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-09-2004, 09:19 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
no... the 1.8L head will not fit on a 2.0L block, nor will a 2.0L head fit on a 1.8L block, just for further referance.
Old 12-10-2004, 12:28 PM
thanks alot guys for your help
