Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 12-09-2004, 06:38 PM
speedster_74 speedster_74 is offline
car wont start!! please help?
my 97 neon DOHC wont start it just shat on me one day and wouldnt run since it acts like it want s to run but it wont its in time so i think all the marks are lined up perfect...alll sensors are good but it still wont fire it acts like it but it wont any help on that would be great thanx.
Old 12-09-2004, 07:36 PM
TEXSRT4 TEXSRT4 is offline
Re: car wont start!! please help?
check spark and fuel. could be coilpack, wires, plugs, fuel pump, injectors.
Old 12-10-2004, 08:01 PM
i checked for all that and it has it all but it still wont start any other help on this would be great thanx.
Old 12-11-2004, 12:22 PM
killer blue killer blue is offline
Send a message via AIM to killer blue
what about abot your fuel sending unit
Old 12-11-2004, 04:23 PM
are you getting fuel to the motor? how about spark? if your getting both, then your timing is off, or you are having a problem with a sensor
Old 12-12-2004, 06:48 PM
i have spark,fuel,and the timing is dead on and replaced the crank sensor, and coil pack,but i have ran out of ideas...any more...thanx
Old 12-13-2004, 10:39 PM
Laveryt Laveryt is offline
you may have fuel pressure at the injectors but it might not be enough.
to see if the car will start at all pour a few tablespoons of gas into the throtle body and try to start it. if it kicks and trys to run then dies. you have a fuel delivery problem.
Most likely the pump not delivering enough fuel or the pressure regulator is broke or a badly pluged fuel filter. like suger in the gas. It will plug up a filter compleatly
My 95 SOHC
http://www.techknowman.com/Dodge%20Neon/Dodge%20Neon.htm
Old 12-14-2004, 07:28 PM
what does it mean when it shoots flames out of the throttle body and theres oil in it...
Old 12-14-2004, 09:16 PM
I would say that you have a motor that is way out of time. or has bent intake valves or both.
how much fuel did you put in there?
maybe too much. but i gather it did't try to run.
My 95 SOHC
Old 12-15-2004, 04:17 PM
how can it be out of time if all the marks are lined up perfect and if you take off the valve cover the lobes on the cams are up and the #1 piston valves is closed it turns over and it acts like it wants to start but it just wont and air comes out of the intake and sometimes it shoot falmes out...i have no idea whats goin on...anymore ideas...thanx
Old 12-15-2004, 05:23 PM
both marks on the cams should face each other at the same time the cranks mark on the crankshaft timing sprocket should point to the arrow mark on the oilpump housing. if thats the way everything is then I would make sure the plug wires are going to the proper cylinder.
#1 the the left most (passenger side of the car) cylinder going 1,2,3,4 to the right.
if its blowing fire out the intake. its out of time at the cams or in the ignition or it has at least 1 bent or stuck open intake valve.
Exhaust cam > <Intake cam
V Oilpump housing
^ Crank shaft.
how are you looking at the crankshaft mark if the pully is on?
if your just assuming that #1 piston is up so that should be good. you would be wrong you could be a lot more off than you might think.
My 95 SOHC
Old 12-15-2004, 05:26 PM
Re: Re: car wont start!! please help?
V Oilpump housing
^ Crank shaft.
it is very likely that your valves are 2 or 3 belt notches too advanced or retarded. this would cause the piston t push some air + fuel back out the intake.
My 95 SOHC
Old 12-15-2004, 07:25 PM
I have changed the timing two or three times now and it still does it... i tried to start it each time and it keeps doing the same thing... I have already got the valves redone and they said the seats were a little thin, but the valves were straight. i dont have any clue what it would be now...iv had the crankshaft pulley off for some time now, just so i could change the timing if needed... anyone have any ideas??? thanks
Old 12-15-2004, 07:35 PM
Im just pulling this out of my A double s but could they have swaped the cams? Intake on Exhaust? I don't even know if that could happen!
My 95 SOHC
Old 12-15-2004, 07:45 PM
if that happened that would mean that it would never be in time no matter what you did rite? i wonderif that is it and im a dumb a**.lol...thanx ill keep you updated.
