I have a 2002 dodge caravan. The oil light comes
on when it is idle. When it is first started up when the engine is cold the motor knocks. It has oil( check it constantly) Could it be the oil pump??? |
Re: oil light comes on when idle
If you lose oil pressure, the oil light comes on. Oil isn't being pumped up to the valves. Knocking noises will come from the area of the valve covers. If the light doesn't eventually go out, don't continue to run the vehicle as damage will occur.
A FAILING oil pump will cold startup ok (i.e. no light, oil is relatively thick). As the engine heats up the oil (the oil is thinning out), a bad pump will lose pressure and the light will come on. |
My oil light came on with the ding, ding sound. I checked oil and the level was good, I added a quart to be sure. When I started the van back up there was no light, about 15 minutes later the ding, ding came back, then the knocking sound started. Is the pump going bad or is there a clog.
typical woman driver, give them a motor, it's destroyed.
Might as well take the van to a junkyard now, ain't worth $50 now. |
