Old 12-09-2004, 05:02 PM
dsmkid95 dsmkid95 is offline
Send a message via AIM to dsmkid95 Send a message via Yahoo to dsmkid95
TD04HL? what kind of turbo is this?
ok so i took pictures of the turbo that im selling and i noticed that it says TD04HL and i typed it into a search and it doesnt say anything about a 14b or t25 turbo. what kind of turbo is this. i took it off of my jdm 7bolt 4g63t motor.
Team Addiktion
155 down the 47
Old 12-09-2004, 06:31 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: TD04HL? what kind of turbo is this?
No idea, JDM motors should have 16g, which are all TD05. T25 is a TD04, but 14b is also a TD05
Old 12-09-2004, 06:44 PM
well this is what someone posted on dsmtuners.com. i dont know if this sounds right.
'TDO4HL-Super 60 Compressor wheel 6CM stage 2 for the 3000 GT VR-4 and Stealth Twin Turbo produces 500cfm each. it increases compressor flow to support over 680HP. This turbo also uses the larger compressor wheel as well as the larger TDO4HL turbine wheel, not the smaller TDO4 wheel found in the factory turbo. These are direct bolt on replacements for the factory turbos and require little modification of factory snorkel pipe for installation.'
just typed it in yahoo.... i think its a 15g
well here, better LINK
Team Addiktion
155 down the 47
Old 12-09-2004, 06:45 PM
right now i have the t-25 that is about to go out and im debating. is it a good turbo? is it worth putting on or should i still go with my s16g. i was going to sell this turbo but if anyone can give me insite as to if its good than i wont sell it. it has 35k original miles on it and i thought it was a 14b and i was gonna sell it for 150 with everything you see in the pic. anyone give me ideas?
Team Addiktion
155 down the 47
Old 12-09-2004, 07:48 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
if the tooners thing is true it seems like it may be a bitch to spool. but a bit more lagg for that kind of power is acceptable. but then you are FWD [assuming] so you may want to keep it down to ~400.
Old 12-09-2004, 09:52 PM
well its not a 15g or a 14b or a t25 so im running out of options here
Team Addiktion
155 down the 47
Old 12-09-2004, 10:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
this is what i found on hahn racecrafts site
"our popular Super series turbos, including our exciting new TD04HL Super 15G"
heres the site its the second paragraph
http://www.hahnracecraft.com/auto/Ma...o%20combos.htm
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-09-2004, 10:11 PM
do you know how this turbo stands up to like a 14b/t25t16g?
Team Addiktion
155 down the 47
Old 12-09-2004, 10:31 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
looks to be better than the t25 and 14b not sure about the 16g, Im not quite sure what really, never heard of it before. I would hold on to it until you can figure out more bout it.
Did this turbo come off your car. what kind of car do you have. If so where did you get the car. Did they modify anything else or what.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 12-09-2004, 11:28 PM
no ive had the car for 2 years and motor blew so i ordered a new jdm 7bolt 4g63t motor. had the new motor installed but the super 15g that was on the new motor would not adapt to anything in the car i.e. hoses lines etc. so we were forced to put the t25 from the old motor back on. so the turbo is just sitting there. i dont know anything about a 15g let alone a super15g.
Team Addiktion
155 down the 47
Old 12-10-2004, 02:53 AM
tyko909 tyko909 is offline
Send a message via Yahoo to tyko909
if you want I will trade you a 14b and a rebuildable t25 for it. then I can worry about what it is
Who needs speed when you push 155.8 dB.... I do!!!
6Bolt cyclone, 16g turbo, AWD, and a 5 speed
Old 12-10-2004, 10:11 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
i know a little about the TD04HL...when my friend got his JDM motor, it came on it...he said when he dropped his motor in and got his car running, his car pulled A LOT harder with this turbo on it than the T-25...the HL model is bigger than the T-25...i ripped mine apart along with my regular TD04...I'm thinking my regular TD04 is around the same size as the T-25...but yeah, the TD04HL is bigger than the T2small
Old 12-10-2004, 07:47 PM
UHM NO
If you find out how many miles are on it and if you can post some pics of it. I think I have someone that is doing a custom turbo job and looking for a turbo a little bigger than the t25.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 12-10-2004, 07:50 PM
I was just posting that as a joke. I really think you should hook it up. after all anythings better than that t25, besides the 14b has only about 3k on it
Old 12-11-2004, 12:08 PM
ok, here are some pics that i posted on tuners.com
maybe this will help a little
http://www.dsmtuners.com/forums/showthread.php?t=156872
Team Addiktion
155 down the 47
