Old 12-09-2004, 04:21 PM
Sivart Sivart is offline
96 model extended cab rear window leak
Does anyone here have any advice on repairing a rear window leak on a 96 model extended cab?
Mine has a lot of wind noise and will leak a bit of water in a down pour. While driving down the road you can pull in on the window latches and the wind noise stops. Any advice would be appreciated.
Old 12-09-2004, 11:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 model extended cab rear window leak
The quick, easy and cheap approach would be clear RTV sealant. Just run a thin bead around the glass.
Old 12-10-2004, 11:39 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
One thing you can try is goto a parts store and buy thin foam weather striping with the adheasive backing and sitck that on around the window. If you can not find any thin enough and if you are pretty handy with a knife or scissors, just trim it down a bit. Or have a look at the latch mechanisim and see if there is any way to slot the mounting holes so that when it closes, it will pull the window in tighter.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
