Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-09-2004, 03:08 PM
Dalt10 Dalt10 is offline
cooling fans
My fans are not working that are on the radiator. Where or what is the first thing to check? Sensor, switch, etc. And where are they located?(sensor, switch, etc). Thanks,
2001 Malibu 3.1
Old 12-15-2004, 08:33 PM
troy1 troy1 is offline
AF -Advisor
are u sure they are not working cuz the wont turn on untill about 228 F
Old 12-17-2004, 07:22 AM
treeman5 treeman5 is offline
If the fans or fan system (relays & switches) aren't working correctly, your check engine light should be on....
Old 01-10-2005, 02:16 AM
krushmoto krushmoto is offline
Try replacing your coolant temp. sensor. I "blew" mine when I didn't drain the air out after changing the thermostat and the car over heated. It's fairly cheap ($13 @ autozone) so even if that's not the cause you know at least 1 sensor is brand new.
