Old 12-09-2004, 01:56 PM
modification_inc's Avatar
modification_inc modification_inc is offline
Send a message via MSN to modification_inc
plastic fuel lines intake
I am in need of new lines in the intake how bad of a job is it and how much 95 blazer 4.3 vortec
thanks
Old 12-09-2004, 03:13 PM
Skeeter6755 Skeeter6755 is offline
Re: plastic fuel lines intake
thanks
I'll tell you what. I had a lot of fun doing this to my 1994 S10 Blazer. The parts for mine from a Dealer was $88 US dollars.
You have to take off the penulum and look for washing. If you see that the lines are cracked (washing on the driver-side) then they should be replaced. It's good practice to also change out the CPI unit while you are under there since they are both prone to breaking.
Release the fuel pressure from one of the fuel lines and then get to work! Just take your time and take breaks too if you get pissed...
Good luck!
Old 12-09-2004, 03:54 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: plastic fuel lines intake
Good luck!
Perfectly said.
Also, best to use a new plenum gasket as well.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-09-2004, 05:07 PM
tmay11 tmay11 is offline
Re: Re: Re: plastic fuel lines intake
Originally Posted by BlazerLT
Perfectly said.
i would also recomend going ahead and replacing the electrical connector, if not, you will at least need the rubber gromment that goes underneath it, mine was all torn up
Old 12-09-2004, 07:20 PM
BlazerLT's Avatar
AF -Advisor
in most cases , the wiring wil not be the cause of the problem.
