Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-09-2004, 01:47 PM
Ohnikeman Ohnikeman is offline
Send a message via AIM to Ohnikeman
Question Rear hatch Lock
The silver push button hatch relase lock on my 94' rodeo no longer locks. It still pops the glass up but i cannot get it to lock. I tried graphite and everythign but it seems to be clogged. I wasnt to replace it but i cant seem to find any place that sells the lock cylinder. Where can i find it?
Old 12-09-2004, 07:48 PM
Pakeboy2's Avatar
Pakeboy2 Pakeboy2 is offline
Send a message via AIM to Pakeboy2
Re: Rear hatch Lock
My daughter just informed me that hers didn't lock either...I got my trusty Mobile 1 oil spray can out and sprayed the c**p out of it and lo and behold it locks...yippee!
1999 Chevy Tahoe LT 4 dr.<---got flooded out/totaled
Now we have a 1999 Chevy Suburban LT, same color and
interior as the Tahoe, just 22 inches longer, has the 3rd seat and a BIGGER gas tank
1995 Honda Passport 2 whl dr.
1992 Mazda Protege DX-5 spd.
2005 Keystone Outback 21RS
~~~HAWAIIAN STYLE~~~
cardomain.com/memberpage/621985
cardomain.com/memberpage/643906
weedlesswillie.com
Old 12-09-2004, 08:59 PM
I sprayed mine real good with WD40 as well, alot of gunk came out which lead me to belive that someone tried to lube it before and the lube has broken down now and doesnt work.
Old 12-10-2004, 01:00 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Re: Rear hatch Lock
try the WD40, but work the key in and out to "excersize" the pins in the lock cylinder. You may have a pin stuck that won't allow the cylinder to turn.
Does it turn on direction and not the other, or not at all?
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 12-10-2004, 01:06 PM
Re: Rear hatch Lock
not at all, when i put the key in i dont even hear the pins hitting it, like they are all stuck in the outward position
Old 12-11-2004, 10:54 AM
Cat Fuzz Cat Fuzz is offline
Sounds like its just gunked up really bad. You might want to consider removing it so you can let it soak in some carb cleaner or something. Don't forget to re-lube it after cleaning.
Old 12-13-2004, 09:57 AM
Re: Rear hatch Lock
you could also try some graphite lock spray, it has cleaner and lube in it, available at just about any auto parts store. If that doesn't work then your going to need some professional help. Unless you feel comfortable taking it apart yourself.
Old 12-15-2004, 09:17 PM
Re: Rear hatch Lock
the carb cleaner has alot better chance of working than the graphite, I have put graphite in before, i need to remove more stuff from the cylinder, not add more gunk
