Old 12-09-2004, 01:24 PM
2000-redrider 2000-redrider is offline
masking alternative
Just wondering if anyone has tried using Glad Press and Seal wrap as an alternative to masking tape. It's transparent, conforms to curves, cuts easily, and sticks to just about anything. It removes easily and leaves no residue. Sound too good to be true? Well, it may be. From what I've found so far, it may not be compatible with the Tamiya TS paints. It's the only test I've done so far, and I applied the paint very heavily. I plan to experiment some more using different kinds of paint and different application techniques. I'll keep you posted on my findings.
Old 12-09-2004, 01:47 PM
freakray freakray is offline
AF Modelrater
Re: masking alternative
It's incompatible with any lacquer paint for a start, I don't think you're going to find much happiness trying to use glad seal for masking.
AF User Guidelines
Old 12-09-2004, 01:56 PM
How is it with Tamiya acrylics?
Old 12-09-2004, 02:08 PM
Jay! Jay! is offline
Horizontally Opposed
It seems to me that the texture of the film would prevent ever getting a true, solid masking line.
Hierarchy of Subaru:
(Click to see mine!)
Old 12-09-2004, 02:59 PM
PlumbedandWired's Avatar
PlumbedandWired PlumbedandWired is offline
I've found that Cling Film is good for masking large areas with masking tape being used for the actual paint separation line. One word of caution....always let your paint cure completely before using Cling Film otherwise it will leave marks.
Old 12-09-2004, 03:41 PM
minniebanister minniebanister is offline
I tried it with Tamiya acrylics (in jars). It left marks in the color I was masking and the color I was spraying ran in under the seam. In other words, it was useless.
Old 12-09-2004, 04:34 PM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
What about Elmores Glue?
Old 12-10-2004, 08:51 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I had it leave a sticky residue when I used it to mask clear windows to paint the black trim on the inside. The residue didn't want to come off easily and that was on raw polished plastic. - Mark
Old 12-10-2004, 09:31 AM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
Parafilm works great!
http://www.clubhyper.com/reference/u...rafilmda_1.htm
Old 12-10-2004, 09:37 PM
Thanks for the link JT, I checked that out and found that the Australian distributer is just around the corner from the place I moved into today!!
